*Fixed
http://i921.photobucket.com/albums/a...0sreencap1.jpg
http://i921.photobucket.com/albums/a...screencap2.jpg
i7 920 @4620mhz (3849B018) water cooled
GA-EX58-UD5
3x2gb OCZ3P1600LV6GK
2x 4870
antec sg850
*Fixed
GA-EX58-UD5
2x 4870
antec sg850
@ mattgmann:
Congrats on one of the golden chips, and good job following the rules - you're in! :up:
Edit: okay, I believe operation "Clean Up" is a success! Now to add the pretty stuff, such as colour coding. :yepp:
Houston, we have a problem, though! SteveRo, your very top amazing 5200.7MHz submission would not show a screenshot anymore. Please work on getting it back, sir, otherwise how I can't really prove it was there in the first place.
OK here is mine, I have not tried to push further but I could try later :up:
http://img.photobucket.com/albums/v64/hmj2k3/4515.jpg
Info :
core i7 980x Batch# 3013A525
Core i7 980x Batch 3031A243
Vcore: 1.28v Idle / 1.29v Full Load
VTT: 1.25v / VDIMM: 1.61v
Gigabyte X58A-UD7
6G OCZ Platinum 1600 7-7-7-21 1T
Air Cooler - Megahalems + Ultrakaze´s
ROOM TEMP: 26.3 c
http://img710.imageshack.us/img710/5...inxfulllll.jpg
http://img405.imageshack.us/img405/3303/dscn5726x.jpg
Both of you, failure to read the OP...
Edit: updated my sig, hope people will realise now.
cheapseats | C2D E8600 [2C] @ 4504.0MHz | 1.392 | ASUS Rampage Extreme | Air | Q820A606
vid 1.25
Noctua NH-U12P + 1x NF-P12 fan
here's mine for C2D category :)
http://i447.photobucket.com/albums/q...02_4GB_L20.gif
http://i447.photobucket.com/albums/q...02_4GB_L25.gif
Please sir may I play in your club :)
Think I got the submission right.... I'll run it again if I've missed something
Air cooling 14oC ambient 1 x medium speed 120mm fan on Megahalems
Gigabyte GA-P67A-UD5
i5 2500K L041B517
OCZ3P2000C8LV4GK
HD6950
OCZ/Turbo Cool 1200W PSU
http://i106.photobucket.com/albums/m...66-797301T.png
Sexy C-N!
@Zalbard: Going to start a *new* 5Ghz club for SB?
Ok, one more time :shakes:
Here you go :
http://img.photobucket.com/albums/v64/hmj2k3/4546.jpg
edit
Read the rules.
1. 1024 mb used in linx out of 8 GB. Are you kidding me?
2. Who cares about cinebench.
First OC , I think setting are correct i did select the "all" for memory but not sure if i did it , 4Gb is installed ,
MB is a gigabyte H55N-USB3 , CPU (I3-560) is water Cooled , If Somethings wrong i will redo the Test :) .
Batch # L013B634
Intel Core i7 860 CPU
full batch number: L925B479
motherboard: Asus Maximus III Gene rev 1.00 (BIOS version 2001)
cooling: water; Magicool 480mm rad, Apogee XT block, Panworld 40px pump
It took me a while (I remember when this thread was new), but I finally got my i7 860 to clock 4.5GHz stable with the help of a mb BIOS upgrade! :clap:
Validation: http://valid.canardpc.com/show_oc.php?id=1584844
http://i279.photobucket.com/albums/k...5GHzclubSS.png
Had mine ready,but i can't post it since i only did 20 runs rather than 21,even though it took 90 mins to complete since i was using a 5 GB memory space,and yes,i do have even more memory installed in the system(12GB),but i'm sure as hell not looking at LinX for 3 hours for a 21 pass run using all 12 GB....:p:
Well .... it's very hot ... but it's the fastest yet :D
http://i56.tinypic.com/b7xgso.png
So is there going to be a 5Ghz thread now all these SB chips seem to be able to do that on air. Almost makes this thread out of date. :rofl:
Shouldn't the list in the OP be updated already!
So if 4.5 was challenge for old i7s, and SB gets 5 on Air, what clocks would be challenge for SB? 5.2? 5.5? And foremost - should it be in separate thread/club? :)
