I was wondering what other people are running their EB sticks at? Specially on AMD 64 boards..
so far i have been able to hit 250 @ 2.90V
here is a screenie:
http://img.photobucket.com/albums/v4...rmula/cpuz.jpg
thanks :banana:
here is a screenie:
thanks :banana:
3V to 3.1V got me 260+ with many modules...I maxed out my own modules with 3V but they all need good cooling.
I suggest you cool em well and you should do well.
I can do 250Mhz 3-2-2-11 on my K8N NEO2 with my 2X512MB 3700EB with 2.9v. Currently running it at 2.5-2-2-10 with 2.9v.
My 1x512MB 3700 EB does and/or I am now running it 3-2-2-10@250MHz@3.1V and it is prime stable....
(settings are 3-2-10-2-11-15-a-2-2-2-a-a-a-0-2-6-5-a-e-8-4-a)
or then 285MHz@3-3-2-8@3.2V
max clocks using 3.5V are 292MHz.... but not stable... ;)
2x256 OCZ EB 3500 ... not bad!
http://mitglied.lycos.de/siedl/10x25..._2_6_36sek.jpg
Why is 2.5 so much of a barrier or common stable OC for AMDs...
I mean, now 2.6 is all of a suden - whoa, you got a 2.6, Celebrate :banana:
257 3-3-2-8 with 2.8vdimm on my epos 9nda3+. 247 3-2-2-10 with same 2.8vdimm. superpi/3dmark stable. 250 would prolly run but i need a better fan blowing over my sticks, plus there right on top of eachother in this board. also thats 2x512 in DC.
check this out :D
http://members.home.nl/epsilon/temp/...293_3700EB.jpg
290 3-2-2... def one of the better 3700eb sticks :D
3.5v
1.85v vcore
modded mach1
dfi lanparty
almost 3ghz... and 290 3-2-2... damn damn damn :slobber:
lol, what did he do make a waterjacket for it? lol thats nuts.
At 3Ghz, thats what Im talking about...though I wished you could do 2.7 on that without having to use your modded Mach 1Quote:
you mean 2.7ghz on air? some of the 90nm chips seem to hit that speed :DQuote:
Originally Posted by perkam
my 130nm chip will do 2.7 on air
Than you must have one of the rarest 3500+s on the market. I'll believe it when I'll see it Mongoose420Quote:
Originally Posted by Mrki
NOT BAD??? It's really hard to get stable 250 with 2 sticks on a 754. I'll be putting my system together next week, and I can only pray I'll hit 250 w/ 2 sticks. I'll be happy with 230 @ 3-2-2-10 1T
yea, best one ive seen in fact. I didnt say 100% stable@2.7 but stable enough for superpi 1m/pifast/3dmark01. 3dmark01@246x11 1:1 in sig with all the details. there's pifast at 2695mhz, that close enough?Quote:
Hehe ...Quote:
Originally Posted by Grayson Carlyle
Yes goods Results and Prime stable ... I post the screen today!
Timings are ... 2.5-2-2-6-10-12 :) @ 3.1VDimm
@3.2V, Abit AI7. 255 prime stable,
http://www.thelab.gr/RootX/Benchies/...ndra/EB266.jpg
That's where mine top out as well - I'm able to run 268 stable @ 3.2V, 3.0-2-2 on the Abit AS8 (865PE).
I´m currently running my 3200EB in my backup rigg...until I get my new stuff.
This is a crapy Max3 with a 350w PSU...with very low rails...so voltage is al over the place.... using vdimm above 3v is a no go...vtt is absolute crap and above 3.0 everything gets worse. My 2.6 800fsb starts to crap out at 250fsb....can´t get any stability at any voltage above 250fsb...anyhing over 260 is an absolute no go with air. And I´m running latest Omegadrivers(Quality) with gaming settings on my FX5950....so plzz don´t mind the 3dmk...it´s just for proving level of stability.
With my new system(939 :banana: ) I´m absolute sure I can squezze out alot more from thoose wonderful chips.
Highest 3dmk01 stable with 2,5-5-2-2 and 3.0v... 2x512mb DC
http://www.xtremesystems.org/forums/...id=17950&stc=1
Still sandra stable
http://www.xtremesystems.org/forums/...id=17948&stc=1
Highest I could get in to windows...but without any stability what so ever...because of the cpu.
http://www.xtremesystems.org/forums/...id=17951&stc=1
You know mine notor, about 257mhz is max on mine. I was able to hit 260mhz for a few mins before it chrased at 2.9vdimm. Just a tad bit more vdimm is all I need.
very nice guys :D ..keep them coming! :banana:
I'm very happy with mine too. The best I could currently do with my EB's is 292 @ 3.0-2-2-5-10-16-1T with only 3.2V, After that my proc is holding me back. On my :banana::banana::banana::banana:ty Epox board the 9 multi doesn't work very well, I reach better cpu / HTT / mem speeds with 10 x.
Link to old pic: http://members.home.nl/youpy/a64prom11.jpg
That is insane O/Cing :eek: .. what kinda cooling you are using? temps? could you please post some superpi(1mb) and sandra benches?Quote:
Originally Posted by YoupY
thanks!
At 3.5v, thats pretty much the trick :DQuote:
Originally Posted by saaya
Just plain air :DQuote:
Originally Posted by Mongoose420
Btw this stick does 295 on those timings. This CPU does 2689on water so 9x290 is a nice speed for lanparty's and stuff :D.
Mem isn't cooled at all. I ripped of the spreaders and gained a lot of mhz. This mem tends to run very hot and the spreaders keep all the warmth on the mem. But running @ 292 also makes the mem pretty hot. With a good board and some cooling on the mem I probally can reach the 300 sync.Quote:
Originally Posted by notoriousformula
I hope at least :D
