2-Stage Cascade Project
Its time for the next step in Phase Change cooling, so decided to build a 2 Stage Cascade.
It will consist of:
1st Stage
- Mitsubishi RE313VDMT Rotary 18k BTU/31.3cc
- 3KW Condenser 43x38x17CM
- 30cm Fan 25Watt
- 1.1L Receiver
- Danfoss TS2 TEV metering device
- Danfoss Eliminator molecular filter 1/4''
- Danfoss KP17 Pressostat
- Sight Glass
- Hi/Lo Manometers
- XMT7100 Thermometer
- R404a
1st and 2nd Stage will meet in an 40Plate HX
2nd Stage
- Mitsubishi RE207VHSMT Rotary 12k BTU/20.7cc
- Oil Separator 1/2''
- BartX 54mm Evaporator
- Tecumseh 2.35L Expansion Tank
- Hi/Lo Manometers
- XMT 7100 Thermometer
- R1150
Cascade will build in a 52x75cm Base Plate
https://i.ibb.co/gr4xvMF/IMG-20210323-170938.jpg
https://i.ibb.co/HxKhN5w/IMG-20210323-231834.jpg
https://i.ibb.co/nrjQrQ8/IMG-20210328-174359.jpg
https://i.ibb.co/n33LGK0/IMG-20210327-214724.jpg
https://i.ibb.co/VmgtBmt/IMG-20210327-214739.jpg
You have some really awesome parts, good luck with the build!
Very clean looking, you're making good progress on the build! What temps and load are you aiming to achieve? :)
Thanks, I would like to have -115C idle/-100C Load @ 350-400w.
A little more progress
https://i.ibb.co/6n05g1h/IMG-20210408-190517.jpg
https://i.ibb.co/5WndPwS/IMG-20210408-190556.jpg
And the thermostat for automatic power on the 2nd stage when 1st stage goes down to -40C
https://i.ibb.co/svtsV2j/IMG-20210408-121055.jpg
Man thats a very nice clean build !
I wish I put more time into making mine look nice, people are kinda shocked at how frankenstein mine looks. A really nice build
Thanks, its a really compact cascade, a bit tricky to fit them all in 50x70cm base but I am used to work in limited space :) ( human abdomen )
Thanks for the updates, very clean work. When I built my cascade 20 years ago, I waited until I had everything before I assembled and when I assembled it took me 24 hours to finish gassing the third stage.
Beautiful Work. I always thought that phase systems should be totally encased because I was dedicating the unit to one build at a time.
Fantastic results and quality craftsmanship. How has the overclocking experience been for you so far with those temperatures?
Very clean build, looks fantastic and seems to perform very nicely! I am beyond envious that you can get ethylene, I've been wanting that for the last 20 years or so.
