http://i42.tinypic.com/2ci70yd.jpg :up:
Built in 2003
Built in 2003
I remember seeing this years ago, when I was still a lurker. :) How is it going?
From what I see it is less of a "cold bug" or "cold boot" issue and more of a "Well what do I get?"
The chips just max out on air/water.
You still have it up and running?
Looks good man !!
Sorry I couldn't talk long on the phone today, they do make me get out and do things from time to time :)
The story about Intels not working well with phase is back when we had chips like QX9650 all the way to 920's is they ran to hot for the phase units back then. Now with Sandy Bridge and after those old units work fine. 3960x's and higher, or the 6 core chips need higher power phase units tho.
I remember when I put a CRYO-Z on a QX9770 and it could not even handle a stock system on the desktop :(
no more I have the computer case only I gave to my buddy....he still has it, everything else I gave away or trashed, I went to Vapochill XEII I went thru 2 of them.......then another builder Jinu for the phase.change unit I keeped my vaporchill case ...........watch for pix
http://i39.tinypic.com/f522b7.jpg
1220 watt power supply is at the top of the whole unit where the compressor use to be, this is the VaporChill XEII but the phase.change was built by Jinu in 2006 approx.
http://i40.tinypic.com/1zwmf44.jpg
by the way under the evap and video card is the PCiE OCZ Revo3 x2 Raid0 SSD it has 2 bright Blue Leds, 240,000iops
very very very fast ssd reads at about 1600 mb/s writes 1350mb/s.....this board and cpu pix is a few weeks ago...its running a fx9590 and CH5-Z board right now
http://i40.tinypic.com/14bhv6f.jpg
here ya go forgot I took pix ch5-z 9590 full throttle
http://i40.tinypic.com/rt1a2w.jpg
I wana thank "sdgserv" for getting me into computers from 2002 or sooner thanks cousin!
for your Christmas present for 2013 you can just keep the: Atto SAS H608 PciE Host Buss Adaptor 6/gbs and the SAS UltraStar 15000 Rpm 600gb HHD.... 64mb cache 3.5 that you have been using, it's now your's
Merry Christmas sdgserv
And that puppy is still running correct ?
Its a beast man ! :)
Nice build you did there :)
