I'm thinking about combining my 2 loops into one. Both of my D5's have an EK top with a res connected to the inlet. Can I run the outlet of the first pump into the res attached to the second pump without any loss of head pressure?
Is there any particular reason for the 4" of space? I have the EK Multires attached to both pumps and was just thinking of going from the outlet to one of the side inlets on the reservoir. The combo's are mounted to the back of my MB tray and I didn't want to have to move anything.
Oh, and a little off topic, but I am running a d-tek Fuzion V1, DD MPC Chipset block, Koolance GTX 295 block (dual pcb) with a PA120.3 and MCR220. Throwing in a few koolance VL3N quick disconnects won't be a problem with flow, right?
Ditch one of the reservoirs, no need for two, otherwise it should be fine.
It'll be fine if you want them both as long as there is sufficient water in the the reservoirs. Don't leave a lot of air volume in each.
