Please recomend memory
Guys I need your expertise I need good overclocking memory 8GB total for my EVGA P55 SLI LE E653 that will overlock at rated speed - 200*8 = 1600MHz Im runnig a i5 750 at 4 ghz. with 4GB ram and I keep running low on memory when playing games. Thanks in advance
Where are you located and what's your budget?
I would have a look at these
http://www.crucial.com/uk/store/list...cal~/list.html
Bit of OC headroom, not expensive & low latency.
Any of the brand name 1600 MHz. 8 GB. RAM kits will serve you just fine. There is no point in paying extra for higher frequency or lower latency RAM that doesn't deliver any tangible system performance gains.
