Project "Little Angel": Sleeving pattern testing!
http://i.imgur.com/SFQlM.jpg
- Sponsors -
http://i.imgur.com/0s805.pnghttp://i.imgur.com/qpjwr.pnghttp://i.imgur.com/OAY39.pnghttp://i.imgur.com/4rQiA.png
http://i.imgur.com/uhjne.png http://i.imgur.com/yvTv0.png
Aquatuning España / Atlas Informática / NZXT
ProSilentPC / Seasonic / IzarMicro
Gracias a todos los sponsors por colaborar en el proyecto.
Many thanks to all the sponsors for the support given to this project
-[ Hardware ]-
Case: Little Devil PC V8 - White (OK)
Mother board: ¿? (WAITING)
CPU: ¿? (WAITING)
RAM: ¿? (WAITING)
GPU’s: ¿? (WAITING)
PSU: 2 x Seasonic X-850 (sponsored by Seasonic)
-[ Water Cooling Parts ]-
Pumps: 2 x MCP655 (WAITING)
Rads: 3 x ¿? (WAITING)
Reservoir: ¿? (WAITING)
Fans: 13 x 120mm NZXT (NZXTFX120LB) and 2 x 140mm NZXT (NZXTFX140LB) (ORDERED)
Fittings: Bitspower, Matt Black in 19/13 (waiting for more...)
Diagnostic: Aquaero 5 XT (WAITING)
Extras: Aquaero 5 XT Accesories (OK)
Tubo: Primochill Primoflex – White 19/13 (OK)
Killcoil: 3 x Pulsar Modding (OK)
-[ Other ]-
Wiring: 18 AWG for custom PSU length wires and 24 AWG for fans (OK)
Connectors and pins: To use with Aquaero, Mother Board, sound card...(OK)
MDPC-X: Washers, nuts, sleeving, heatshrink etc.. (WAITING)
Hello everyone! I've been around for a while but most of the time reading and learning from all the active members of XS!
This is a Big Update system I was waiting for the last couple of years, I will change from a e8500 to a i7 2600k or 2700k if it’s really worth it!
Maybe If the build takes longer Ivy Bridge… but don’t think they will release them anytime “soon”
Xtremesystems is the responsible of taking me back to Water Cooling.
8 Years ago I already had a fully Water Cooled rig, but after couple of years rad started to leak, I had to replace tubing and I thought that it was enough water cooling for me so I changed to air cooling and thought that never would use water again… BUT then I joined Xtremesystems in 2008, just after I finished my last “air cooled” rig and decided that my next gaming PC would be Water Cooled again.
So here we are 3 years later ready to start with this build!
Hope you guys like it, will keep the log updated.
Now I have to wait for some parts and wait some time to order some others…
