Greenish Tint/Murky Water
Hey everyone, just wanted to seek your advice as I have been out of the watercooling gig for a few years now. I have an older rig that uses the following components:
1. Koolance i380 waterblock (nickel plated)
2. Alphacool triple rad monsta
3. EK reservoir with Laing D5 Vario pump
4. Mayhem white absorbent tubing
5. Mayhem XT-1 Nuke clear coolant (100ml coolant to 900ml distilled water)
6. Bitspower fittings
I have a single loop from CPU block to radiator to pump. I drained the loop completely and used vinegar/distilled water (30:70) to rinse and clean out my radiator for several hours and then flushed it all out with a few rounds of distilled water ensuring to remove all of the vinegar/distilled water solution. I then used Mayhem XT-1 clear coolant mixed with distilled water to fill in my loop again. Immediately, I can see that the water is very murky with a slight greenish tint. I think the coolant is causing the metals to react or is reacting with the metals itself but I don't know why. The XT-1 nuke is supposed to be compatible with copper and nickel plated and I'm not using any aluminum in my loop.
Here is a picture of it:
https://i.imgur.com/3w5H3KL.jpg
Any ideas why this is happening?
