X570 Aorus Pro modded UEFI
https://i.imgur.com/y9qNWQy.png
Gigabyte modded AM4 X570 / B550 UEFIs
This seems to be the best place for this thread, the point in this firmware is the same as it is for what I've done for the GB X370 boards; to add some polish Gigabyte don't want to do themselves. Feel free to post here with your experiences etc.
EDIT: Well this is an interesting turn of developments. I'll avoid too many specifics for now but apparently there is an EVGA XOC rep, EKWB rep, and Aorus rep actively trying to get me banned from a certain Facebook group, I have no idea what the :banana::banana::banana::banana: the former two would have beef with me for never done anything to them so I assume they are just buddies of the Aorus rep as for the Aorus rep I think we can guess the deal there, they don't like people like me taking in-depth looks at their hardware and telling people both the good and the bad in an objective, unbiased review based on all available information. You accomplished nothing with this move Gigabyte, to me you are so insignificant I wouldn't even bother scraping you off of the soul of my boot should I step on you.
Changes:
General:
Cleaned up some options names
Renamed some options so it is clear what they are
Removed duplicate options
Moved some options to where they make more sense to have them
Added detailed descriptions for numerous options. Eg; Proper descriptions for memory timings
Reconfigured Failsafe and Optimal settings for better compatibility with some hardware
Tuned default fan control so it's hopefully less monotonous for people customising them
Corrected numerous typos made by GB/AMD
NVRAM is automatically reset when firmware updates
Boot Block is automatically updated with firmware update
Renamed Plug In Devices Info to Hardware Explorer
Disabled Q-Flash checksum check so you can flash as you would any other firmware
Fixes:
Fixed USB keyboards not waking from sleep mode in the UEFI
Fixed USB LED mouse mats not powering down when the system is shut down (for some dumb reason ErP isn't enabled by default)
Added Stuff:
Force expose Re-Size BAR option (This option was not showing itself with BAR capable hardware, at least not for me)
Added fTPM configuration
Added ACPI configuration
Added PCI Subsystem Settings
Expose Windows 10 Features option
Expose compatibility support module option
Expose display resolution option
Added Chipset Settings menu
Added I2C Configuration
Added UART Configuration
Added chipset configuration
Added SATA Configuration
Added Fusion configuration
Added Chipset options
To Do:
Fix/clean up AMD CBS
Downloads:
X570 Aorus Pro F33c-M2
