L5639, L5520 is for pussies
Can you run less than all of the nodes/motherboards on one of those multi-node/multi motherboard servers?
Typically, yes. You can install one CPU into a quad socket board and run it.
Intel-Xeon-L5630-2-13-GHz-12M-5-86-GT-s-Processor-SLBVD
What do you think of a pair of 5630's seems like fair points per watts value. Does anyone know of some dual 1366 boards that can overclock at all ?
http://www.ebay.com/itm/301083130274...84.m1555.l2649
need to finish my gaming rig lol
E5640 are pretty cheap just liked the low TDP of the 5630's but if I have some overclocking options I could under volt the E5640 if i wanted to. Just did not like the price of the one SR-2 I found lol. Was hoping for around a $200 build for the cpus and motherboards but not sure what the best deals are right now.
cloud rig, 8 L5520's 64 threads at 2.26ghz, 225$+shipping
http://hardforum.com/showthread.php?t=1803372
Yeah but the L5639's and 5640's are 60W vs 40W and six cores vs. 4 cores. Also, just based on the benchmark numbers for regular dual E5630's you aren't really getting that much bang for your buck.
http://www.cpubenchmark.net/cpu.php?...250&cpuCount=2
You won't be able to find a dual LGA 1366 motherboard and decent 5500/5600 CPU's for $200. Once in a while I see some used Supermicro X8 boards for $100 and matched pairs of X5570's for $150.
Also you are forgetting about needing heatsinks(2). And you'll need a beefy enough PSU for two processors.
That's actually a pretty good deal. I haven't seen a dual node/dual board deal like that since before Christmas, and that didn't include CPU's. Though you will end up paying for a HSF, drive(s), drive sleds, and RAM. Still, cheaper than assembling two whole system from scratch. And you could always find some faster CPU's at a later date.
Side note - does hardforum hate Newegg or something? Every time I click a link someone posted they put this large annoying message in the center of the screen to use some plugin to shop at Newegg and buy from Amazon "for cheaper" (which in my experience is only on a few items here and there anyway). Really annoying.
I?d kill to have the c6100 with 8x L5639 s :O
http://www.ebay.co.uk/itm/QA8Z-ES-IN...item258b6d63d0
cheapest I have seen these for >12 months. They are fitted to my rig listed 3rd here: http://nikita.tnnet.fi/~evntr/xs/ they do 2.4 loaded
works in original bios on both asus z9PE-D8 WS and Supermicro X9Dai Not so sure about later bios
About 178 Kw/h per month which is not a lot more than a 2600K/3770K overclocked to get Half the points. based on that the the cost of 2 IB rigs over here is about $2k for the good stuff. For the rig in question I paid a total of $1470 which is about what I would expect to have to pay for 2 secondhand 3770K setups. Agreed....that is a lot but if I save 150Kw/hrs per month
based on the above assumptions:
Cost of ownership for 3 years this rig is $3286 and $605 per year after
cost of ownership for 3 years 2* overclocked 3770K's is $4497 and $1009 per year after
aaah.... The joys of living in UK with the associated taxes and power bills.
Supermicro H8QME-2+ Motherboard Quad AMD Socket Support 6-CORE/QUAD/DUAL CPU
Includes: 4x AMD Opteron 8216 CPUs, 1 x Riser Card RSC-RR1U-E16 , 1 x AOC-SIMSO-Q Remote Management
http://www.ebay.com/itm/111379228765 75USD
Group buy?
I kinda wanna make one happen now
Deal of the century. :eek::shocked:
http://www.ebay.com/itm/450MHs-A2-Te...item2c85935ef6
BWHAHAHAHAHAHAHAHA!!!!!!!!!! :rofl:
interesting thread... maybe i should throw some of my crap up on ebay. have 12x opteron 6272 rigs on supermicro h8dgi-f motherboards, in supermicro cases with the 920w psu. (12 total rigs)
