Price is $1k usd
Only five made :shocked:
https://store.coolermaster.com/us/c7...imited-edition
http://www.coolermaster.com/landing/...mg/c700p-2.png
Price is $1k usd
Not sure what to think and from what I see the carbon accents do not warrant the $600 increase in price.
Even at $390 it is an expensive case. I am sure the craftsmanship is excellent.
only five made
It also looks better :shrug:
I just got a Cooler master stacker 830 CSX warfare limited edition
This was around the same price when released
The cheapest custom case I've seen was the InWIN D-frame mini
https://images-na.ssl-images-amazon....yL._SX425_.jpg
http://www.dvtests.com/wp-content/uploads/2010/04/3.jpg
dust collector not the best case for crazy price
Why not have the extra cooling bracket for the bottom included. If you buy a $1k version of a case it should come with all of the optional brackets.
Coolermaster CSX Stacker 830 vs Alienware predator 2.0b
The outside doesn't seem much bigger,but there's so much more play area now.:D
I can fit 2x 360mm rads + a 280 w/ no mods
Alienware only supports 2*120mm
Holds 13 3.5 Hdd's + up to 8 2.5 ssd's (4 on each side of hdd rack)
Alienware only supports 4*3.5 or 8*2.5:rolleyes:
13 fans in push and 22 fans in push/pull
Alienware only has 4 or 6 w/ 2*120mm rads in push/pull
There's also 12 5.25 bays
Alienware only has 3
Removable Mobo tray w/inverted layout support.
The c700p has chimney layout support.:shocked:
The alienware cases did come w/Soundproofing and built in RGB.
Just needs to be modded to reach its full potential
Thinking about carbon fiber vinyl and matte white paint W/the mdpc fan grills.
Drilling 4*140mm or 3*120+2*140mm holes 2/3@top and 2@ bottom
Will post in the case/case mod section when I get started on the alienware
Very large psu's no problem for both.:)
There's 3 version of the stacker 830 and the parts are interchangeable
Two diff mobo trays one has cable management cutout and alot of hole behind the cpu socket.
Searching for the later so I wont have to cut anything.:yepp:
https://i.imgur.com/DaCXe2Q.jpg
Those have other accessories like drive sleds, in this case the rad bracket is the optional extra. It is also very cheap and I would assume very needed in a system with a thousand dollar case.
Little to no modding needed though, and tools cost way more than these cases,unless you live near a harbor freight.;)
I like this mod right here: oh boy :shocked:
https://i.imgur.com/LnmlC7b.jpg
C700p modded
https://i.imgur.com/9Yi3JJM.jpg
I may get a custom res from singularity cases.:up:
