chew*, right now, i can't. I've got a sample request in for the 16/32s coming hopefully by End of July.
D
D
Cool no rush just curiosity.
Quick question.
What is to stop a user from slapping two thread rippers in one of those dual socket boards and overclocking with Ryzen Master?
I am fairly certain amd did not make it that simple.
Movieman is watching this post from above lol.
the only thing stopping threadripper would be the presence of infinity fabric between the sockets. additionally, they'd have to turn on the additional electrical lanes for the cross connect which may/may not be fused out of Threadripper. i could technically try to use Ryzen Master on these Epycs. lol
D
That would be awesome if it works.
dual opty 6386 still works @4,3GHz:
Cinebench R15 Extreme Edition 1950X@3,9GHz_1,17V_Asrock X399 Taichi_4x8GB Gskill DDR3200 CL14
Ryzen 2990wx Stock, Cinebench Extreme
http://3800z24.info/Ryzen/2990wx/2990wx_Cine-extr.PNG
wow, did you PC upgrade?
That is a secondary test rig. :)
There's a new cinebench r20. For now you must download it via ms store, no need to log in. link
After it's installed, it's possible to just copy its app\bin folder and store it elsewhere, it's just a x86 exe as the older releases. Scores will be saved at documents\maxon\Cinebench_20.040
2009 run! (no tweaking, just the prime stable daily cfg)
http://www.xtremesystems.org/forums/...9&d=1551869876
edit: Techpowerup has repacked it in a zip: Portable CB R20 Download
Quick 2700x run at 4.3ghz with Ryzen Master open.
http://3800z24.info/Ryzen/Cinebench20_4.3_2700x.JPG
Cinebench R20 on TR4 1950X@3,9GHz_1,17V_Asrock X399 Taichi_4x8GB Adata Spectrix D80 DDR3200 CL14
2990wx Stock 64GB RAM 2133mhz
http://3800z24.info/Ryzen/2990wx/2990wx-cine20.png
Cinebench R20 on TR4 2950X@4,125GHz_1,2V_Asrock X399 Taichi_4x8GB Adata Spectrix D80 DDR3200 CL14
I must to try new toy guys :) Im not so extreme to have 2990WX, but I needed also Threadripper of 2nd gen, so 2920X :).
