He get stuck in the low profile becuase the card is getting errors perhaps.
Also Palit has a new bios for their 460s, I strongly suggest using it..
@KET: FYI I was actually refering to the lines/traces on the mobo;)
Tried again, this time with a clean driver install, but no luck...
Everything seems to go smoothly for a while, but then it gets stuck, and all I can do is to reboot my PC to get the "normal" clocks again.
Also the problem seems to start as soon as I try to change the memory clocks.
If I move them to anything other than 2000 MHz (in Afterburner), it gets stuck.
No matter the load on the card (with Kombustor running and GPU ussage at 99%), they all remain on those values (800/1600/325 => core/shaders/memory).
UPDATE:
I'm currently testing the new BIOS U posted.
So far it seems to work better, because I can change the memory clock and it doesn't get stuck with the slow profile.
The only thing that I'm missing now is the fan starting point/lower limit. On my case, the default 40% is absolutely unnecessary. At 30% the card maintained the same temps and was a lot more quiet (actually at 40% the fan [on my card] starts to vibrate, generating quite an annoying sound. I have to manually adjust the starting point to 42% where is QUIETER!).
Hey guys, Im in a hurry. How I can get the Bios of my EVGA GTX 460 768MB SC Edition and post so you can modified it?
I will be very grateful :)
1. Read the first post
2. Theres no reason why that should be happening unless your card has a dual BIOS. The KFA and Galaxy cards are two that DO have a dual BIOS and as yet nobody knows how to flash the second BIOS as well.
Well...
I've continued testing the latest unlocked BIOS posted by CrazyNutz, and so far it has worked very well.
Does someone know if there is another way to change the fan settings for this BIOS? Right now it's the only thing that bothers me.
New Gigabyte F3 bios released..
here my unlocked bios
http://www.abload.de/img/4g6m5.png
Download:
http://www.mediafire.com/?yulgz17w6cnll9v
http://download.gigabyte.ru/utility/...ity_atbios.exe
http://forum.donanimhaber.com/m_4205...glink_43391945
I know this is a 460 thread and since I haven't seen ( I tried search and no luck ), a 465 thread..... Id like to know if theres any good bios out there for a 465, they are both MSI| N465GTX-M2D1G and they are currently wc .
Yey! I have done it. BTW, I found a guide wich explain how to unlock the cap voltage of my VGA, is anyone need it, I will post the link. BTW, how I change the fan speed to 100% and the other things? The guide is lack of that information wich is really useful.
Now I have to create a bootable pendrive and its ready :)
BTW guys, here is the clean Bios of the EVGA GTX460 768MB SC.
Dear All,
I would like to upload a Palit GTX 460 768Mb non reference desing BIOS, and I would like that the only thing modified to it should be the voltage protection taken off. Can that be done? What do I use in order to save the BIOS?
Respect,
H3x0r
That would make the job. Beside, if you want to change the voltage cap, you can do it simply by following this guide:
http://www.evga.com/forums/tm.aspx?m=596592
If I can't link to that forum, please forgive me, tell me and I will edit my post.
BTW, hope it can help you.
As soon as all my GTX460 are under water, i flash the cards with this bios !
Updated vBIOSes pack.
Just received my 2 MCW80 :D
All 3 cards underwater tonight !
ill post pics tonight.
not mounted yet, but the plan is in my head.
ill use teh GT200 plate that comes with it, and make new hole for the GTX460.
1+ for pics :D
yep, the plate can fit. i received the bloc 5 min before going for work ... but i had time to place the GT200 plate behind my GTX460 and it will fit for sure. Just need new hole in it !
Youll have pics tonight. im at job till 23h pm ( its 22h08 ). After its going to be a watercooling party in my house !
