1. GPUGrid's science projects only run on NVidia, at one point they started mining bit coins to help fund the research, I'm not sure they are even doing that nay more.
2. The BOINC client version you have now is fine.
3. Go to http://www.gpugrid.net/
3.1 Create your account
3.2 if you are running 660Ti or higher go to your GPU Grid preferences and select ACEMD Long runs and unselect the others
3.3 Join XtremeSystems team
4. No need to re-install BOINC
4.1 Open BOINC Manager and from the Tools menu select Add project or account manager
4.2 Select add project, select GPUGrid and follow the wizard
5. I don't think you will need to update your app_config file at all
6. BOINC will divide you GPU time between WCG and GPUGrid based on the "resource share" you set for each project (in project preferences)
7. GPUGrid is way more demanding on your GPU than HCC so I would suggest turning down your OC until you start to get a feel for temps and faults.
- I'll be brining some cards back here when WCG HCC finishes (only so much electricity in the house)
good luck and enjoy crunching :up:
Snow
From my most recent research at http://www.gpugrid.net/forum_thread.php?id=3319#29081
An app_config.xml file could/should look like this...
<app_config>
<app>
<name>acemdbeta</name>
<max_concurrent>9999</max_concurrent>
<gpu_versions>
<gpu_usage>1</gpu_usage>
<cpu_usage>0.001</cpu_usage>
</gpu_versions>
</app>
<app>
<name>acemdlong</name>
<gpu_versions>
</gpu_versions>
</app>
<app>
<name>acemd2</name>
<gpu_versions>
</gpu_versions>
</app>
<app>
<name>acemdshort</name>
<gpu_versions>
</gpu_versions>
</app>
</app_config>
Specifically, at least I now know how the <name> need to be modify.
Can anyone answer my question... WCG has a web page that provides a Team with a weekly Point and Result listing.
https://secure.worldcommunitygrid.or...rdsPerPage=100
Does GPUGrid.net have the same/similar thing for it's teams?
GPUGrid would not accept my computer. Must be my GPUs.
There is no need to app_config at GPUGrid.
What cards are you running?
GPUGrid stats have team member totals and PPD average.
Most of us use Boinc Stats http://boincstats.com/en
and/ or FreeDC (but iis down for the moment)
http://stats.free-dc.org/stats.php
