[News] AMD Radeon RX 470/460 Official Specifications [Update: 460 @ 99$ 470 @ 149$]
https://www.techpowerup.com/224493/a...cations-leaked
The official specifications of two the two upcoming mainstream graphics cards by AMD, the Radeon RX 470, and the Radeon RX 460, were leaked to the web as slides from the company's official press presentation ahead of their early-August product launches. The RX 470 is based on the same "Ellesmere" Polaris10 silicon as the RX 480. It features 2,048 stream processors across 32 GCN compute units; 128 TMUs, 32 ROPs, and 4 GB of memory across a 256-bit wide GDDR5 memory interface.
The RX 470 features clock speeds of 926 MHz core, 1206 MHz boost, and 6.6 Gbps memory, working out to 211 GB/s memory bandwidth. The RX 460, on the other hand, is based on the "Baffin" Polaris11 silicon, featuring 896 stream processors, 48 TMUs, 16 ROPs, and 4 GB of memory across a 128-bit wide GDDR5 memory interface. Its core is clocked at 1090 MHz, with 1200 MHz boost, and 7 Gbps memory, working out to 112 GB/s memory bandwidth. The RX 470 draws power from a single 6-pin PCIe power connector as its TDP is rated at 120W; the RX 460 relies entirely on the PCIe slot for its power, as its TDP is rated at <75W. The RX 470 will be available from 4th August, 2016; with the RX 460 following on 8th August.
https://www.techpowerup.com/img/16-07-28/92a.jpg
https://www.techpowerup.com/img/16-07-28/92b.jpg
https://www.techpowerup.com/img/16-07-28/92c.jpg
https://www.techpowerup.com/img/16-07-28/92d.jpg
