:up: Works pretty darn well for me!
I love the 690. I really need to redo mine. Must. Finish. Raven. First. GAH!
I hope you had fun putting that all together.
I think the big part was the fact that my tube routing was all kinds of stupid. Before I got the EX x-res combo res/pump top i had the old res up against the back wall in front of the expansion slots. The tubing was causing the the res to lean up against the wall with a bit of pressure. It lasted for ~2 years like that.
It's possible that I overtightened the res as well. Should have known as we have field service guys at work that get chewed out for overtightened plastic fittings all the time.
And what he said, looks great.
Personally I've got a 690 in the mail to upgrade the wife to a i7-860 while I wait for my chance to get a 980x
it looks right hes using two dual pcb gtx295 or 9800gx2. plus no quoting pics
Hi, new here :)
Wanted to show my build too
http://www.l3p.nl/files/Hardware/Cor...0%5B400%5D.JPG
specs:
i7 950 @ 4.2 Ghz
Asus P6T6 WS Revolution
6 Gb Corsair Dominator
Corsair Obsidian 800D
Corsair HX 1000W
Gainward GTX295
Highpoint 3560 2 GB
2x Intel X25-M 80GB raid0
6x Hitachi 2TB raid5
EK-Supreme HF Nickel
EK-FC295 GTX SLI - Acetal
Koolance MB-ASP6WR (ASUS P6T6 WS Revolution)
MIPS RAM Freezer 6 POM - Corsair Edition - Nickel POM Black
Jon Lund Plex Reservoir POM
2x Laing D5-MCP655
2x Bitspower D5/MCP655 Top
2x Bitspower D5 Mod Kit
Aquacomputer airplex evo 1080
2x Laing D5-MCP655 @ 1
2x Laing D5-MCP655 @ 5
Aquacomputer airplex evo1080 under the floor
vin_tech pls don't quote pics :up:
i am so sorry
Great looking system l3p! Lots of family pictures on 8 Tbs of storage? :D
gg l3p!
Enjoy
http://www.pctunerup.com/up/results/...59_PC_2010.jpg
http://www.pctunerup.com/up/results/..._PC_2010-2.jpg
http://www.pctunerup.com/up/results/..._PC_2010-3.jpg
http://www.pctunerup.com/up/results/..._PC_2010-4.jpg
http://www.pctunerup.com/up/results/..._PC_2010-5.jpg
... I hope my integration is liked, but I will especially appreciate the silence in it thanks to 2 Fan SCYTHE SFF21F SFLEX downvolted with SpeedFan, each at no more than 900/1.000 rpm!
Bye from Italy ;)
Here is my current situation. I just got this case and slowly modding it. The top was already cut for a rad, but my xspc does not fit so I am going to try and figure something out there. That is why my rad is placed to the side right now.
Wire management isn't to par yet, but it will get there when I get the top done.
http://img339.imageshack.us/img339/9493/1000949b.jpg
http://img709.imageshack.us/img709/7826/1000947a.jpg
http://img684.imageshack.us/img684/2559/1000945t.jpg
http://img684.imageshack.us/img684/4307/1000944z.jpg
Its ghetto right now to say the least.
If you keep the top without a radiator, I say get one single black aluminum sheet, and do with it similar to what you have now. I think that's a really cool look. Have it raised like 2mm above the top of the case (like it is) but have it one single piece. File the corners so they aren't sharp, and I think it'll look great like that.
And then that leaves it open for you to add a radiator up there later if you get one to fit.
Yeah that is actually my idea. Those two sheets are from the door actually haha. I took the door off because I didnt really end up liking it on there.
My plan is to either someone get those pieces into one or find a piece and set it on top like that.
Plus when its dark it lets the blue light shine through and looks pretty cool.
New pics of my V350 :)
http://lh5.ggpht.com/_txNEw1YnjZA/S9...SVfntus/01.jpg
http://lh6.ggpht.com/_txNEw1YnjZA/S9...yz6bWcQ/02.jpg
http://lh4.ggpht.com/_txNEw1YnjZA/S9...YC7afz0/03.jpg
http://lh5.ggpht.com/_txNEw1YnjZA/S9...SmGneBE/04.jpg
http://lh4.ggpht.com/_txNEw1YnjZA/S9...QGprTWA/05.jpg
http://lh3.ggpht.com/_txNEw1YnjZA/S9...4epfU_4/06.jpg
