Originally Posted by
NEOAethyr
I didn't even know you could disable avx...
Though I notice aida64 is saying it's disabled as well, but honestly I think it's just a screw up, It's probably working anyways.
There's alot of odd things here and there that don't work on my systems, past and present.
Cpu load, all sorts of perf counters and so on.
Anyways I'm gonna try this bcdedit mod to see if I can force avx to enable or whatever.
Anyways I'm off to play with bcdedit.
Though I doubt aida64 will beable to tell if it's working either way.
Update:
Ok well, forcing avx to enable doesn't work.
Avx is just isn't working on my setup lol, got the os, cpu and etc.
I apparently gutted avx along with float-16 and so on without realizing it, I wouldn't of known with my older amd cpu at the time.
I didn't think there was another say 80% perf boost just waiting for me lol.
I got a fresh os to the side I haven't finished setting up, no tweaks.
I planned on getting around to fixing up my tweaks for x64 win7 but just haven't gotten around to it other then installing windows and calling it quits for the time being, until now anyways.
Sigh I don't even wanna use windows lol, but I don't have the free space right now for linux...
I should try re-stressing my cpu with avx enabled a little later on, I thought I was using it but apparently not...
Linx went from 90 gflops to 160 gflops so apparently not lol.
