Keep in mind that integrating the pump to the rad makes it bigger... and it wouldn't fit in many cases if such thing was done.
Gabe explicitly stated that this pump was not a ddc.
Here's a little bit about the demo we've done in LV - we are going to pack up soon, and will try to answer questions asap =)
The new H220 kit is closer to the new Swiftech Elite kit series than the Edge series.
It is based on the APD2 waterblock/pump combo but instead of using the MCP35X, we've designed and produced a new pump specifically for this new product.
The radiator is the same as the copper/brass based MCR220-QP-Res (same core and fin density w/ fill port) with very minor modifications to make the product more user friendly, a little more compact. It comes with a pair of Helix120-PWM already attached and our PWM splitter.
Tubing is a thick wall 3/8" ID by 5/8" OD and black. Both waterblock/pump and radiator have swivel fittings (3/8" barb) and come with a new aluminum clamped that is easy to use and reusable.
It's basically a AIO LC unit with enough radiator capacity and pumping power to be expanded to a fully custom/enthusiast loop.
Of course the unit comes already filled up and ready to use.
Few (bad - sorry)pictures from the demo:
#pic 1
http://imageshack.us/a/img208/9818/img0319yu.jpg
this is our setup with 4 identical systems
* 4 Nanoxia DS1 case
* 4 Asus Maximus Formula V
* 4 Intel 3770K
* 4 Kingston KHX1600 memory
* 4 Kingston 2k SSD's
* 3 EVGA GTX660 Ti's on 3 of the 4 systems
and 2 EVGA GTX680 Hydrocopper for the 4th systems
All systems are overclocked to the same speed 4.6GHz, same voltage, etc
System 1 system runs the Swiftech H220
System 2 system runs the Corsair H100i
System 3 system runs the Thermaltake Water 2.0 Extreme
last system (system4) also runs our H220 system but with 2 GTX680 liquid cooled and also a VR/Chipset water block
#pic 2
http://imageshack.us/a/img515/8822/img0323k.jpg
This is a close up of the H220 Waterblock/pump our 5th system
This 5th system runs a 3970K, 2x 7900 series graphics cards, the H220 system and 2 additional radiators (MCR220QP / MCR240QP). The idea here is to demonstrate how this single pump can run multiple blocks/rads..
#pic 3
http://imageshack.us/a/img856/8053/img0324ik.jpg
that same 5th system
#pic 4
http://imageshack.us/a/img801/1369/img0325gu.jpg
#pic 5
http://imageshack.us/a/img834/7596/img0326nc.jpg
compared temps for systems 1 through 4:
http://imageshack.us/a/img541/262/tempresults1.png
perf. for system #5
http://img23.imageshack.us/img23/5336/system5bench.jpg
3930K @ 4500MHz
2x 7900 series
H220 stock + 2x EVGA Hydrocopper Blocks for GTX680 + 1x MCR220QP + 1x MCR240QP
all fans are running at 1,000 RPM
Any more details on the testing?
Looks good so far...thanks for sharing..:)
I really had no idea you could get away with just a single 240mm rad for a CPU and GPU, let alone 2 GPUs. I understand why you wouldn't want to in lots of cases, I just didn't think cooling potential was there
Thinking of ordering a couple of these for a few friends. that block+cpu is just ./drool!
Can you give us a Core vs dbA comparison or something that shows the whole picture from min to max of each kit?
We need MOAR!..:)
In case anyone missed it here is the video Linus put up on YT:
http://www.youtube.com/watch?feature...&v=tZgctchIQ7M
I do like those handy swivel joints and tubing. Testing aside, the beefy thick walled 5/8" tubing and swivel fittings along with the expandability is enough to win me over one of the sealed AIO kits. Despite the lack of testing detail, I do like the system and would consider buying one myself, nice kit. That price alone is hard to pass up on a system that is expandable. Looks good guys although it is killing me not seeing inside that pump, I want to see the inner workings!!..:)
Looking very nice , its going to be a great product , Thanks for the information Gabe :up:
haha yeah, I know right but still it works :D
half the wattage doesn't mean half the hydraulic power
enthusiast doesn't necessarily mean overkill :D
testing details: 3 machines with same CPU (o/c voltage/bios settings)/case/memory/OS (ghosted OS)/same everything running at 1,400 RPM all 3 cooling systems - all 8 threads of each CPU loaded to 100% - running coretemp with logging ON. Tests results are displayed off a laptop that reads each Coretemp logs once a second to read the temperature of the 4 cores - averaging them out - and also displaying the average of these 4 cores through the last 10 minutes (we show Current temp / and last 10mn Avg).
the 3 machines were next to each other on the suite's conference table. We ran this demo 27 times from monday night to early friday morning. Difference between H220 and TT water 2.0 Extreme varied from about 1C to 4C. Difference between H220 and Corsair H100i varied from 4C to 7C.
After thermal test demo, we did some noise comparison - I haven't watched the video yet but IRL it was very easy to hear the differences
we'll have much more test data published on the product page soon.
Nice!
Is the black tubing just a 3/8" ID x 5/8" OD or a metric equivalent?
I imagine people wanting to expand from the CPU only will be looking for a few more feet.
Is it similar to Tygon 3400?
http://www.sidewindercomputers.com/tyr33id5odla1.html
could buy one for my bro as a birthday present
That block/pump look great. I can see using a setup like that in my wife's PC, I'm gonna tell her about it. She needs better cooling by far.
Will you make the block/pump setup available by itself, for those wanting to say setup multi-socket boards?
I've got a quad socket that could use them but 4x35x when there's no PWM available seems to be wasteful. Also, 4 sockets. Not made of money, not on this fixed income. Also, I happen to like the aesthetics.
This looks amazing. I'd use this over the Corsair kits simply because I have the ability to refill them when they do have issues. I've avoided the corsair/astek offerings because I can't refill them or repair them once they break. How is bleeding this unit?
My only concern is users might end up buying this, and trying to expand too far with this product based on what it was designed for. I can just see some of my clients asking me now if they can buy this and later on use a 360mm with SLI with this. It would probably work fine, but not as well as a custom-made loop in regards to heat removal.
I'd love to see Swiftech or another water cooling company/retailer make a "build your own kit" with flash/javascript for those whom don't want the pre-made setups. The old ultra kits you guys offered were nice, but offering a selection and even some preset loop setups would be amazing over the "take it or leave it" water cooling kits.
will swiftech be making AMD mounting brackets for the H220?
http://www.youtube.com/watch?v=tZgct...A0Tunw&index=7
wow very impressed
cant wait for reviews on how this performs on an AMD system, preferably with an FX-8350 at 5ghz :D hint hint
Your production guys must be really proud of this, getting this kind of a kit out at this price is a serious feat!
You said the waterblock is basically the same as the Apogee Drive II, does that mean you could swap out the pump for a DDC to make it a ADII if you wanted to upgrade the whole loop? Will you ever release that pump separately?
Is evaporation of the coolant a problem? I would have thought that might become a problem with big diameter regular watercooling tubing. Or are you using some kind of foam in the res to "soak" up air like I've seen in other AIO kits?
Also, I just saw you're located in Long Beach! I'll be visiting some friends there from early to mid-February, is it possible to drop by your offices to chat a little and pick up some stuff?
