I like the black tubing, very sanitary.
Here's my first post (I believe) and my contribution:
http://img406.imageshack.us/img406/1...tsdator479.jpg
http://img52.imageshack.us/img52/116...sdator4114.jpg
http://img706.imageshack.us/img706/8...dator12178.jpg
http://img203.imageshack.us/img203/4...sdator9981.jpg
Looks good man and I love that Raven such a beautiful and different case. That and the FT02 are probably going to be my next picks in casing.
HuffPCair: don't be hasty with choosing RV02 or FT02 cases for liquid cooling. With these pics you can easily see, how much case dimensions limits internal radiator choices. With some longer gpus even more so. And there is lack of options for more rads to add internally (i see only 1x120 on top or taking out whole 5.25/3.25 enclosures). External rad mount can solve that issue, but will ruin clean looks. No matter how i like FT02, i'd take it only for air cooling :( (as less rads = louder fans for same cooling)
Updates:
http://i250.photobucket.com/albums/g...f/DSC08188.jpg
http://img197.imageshack.us/img197/6499/dsc08186y.jpg
http://i250.photobucket.com/albums/g...f/DSC08190.jpg
Another 5970 and a second loop for the vgas are comming!!!
I use a Thermochill Pa120.3 radiator in my Raven 2 case, and theres 3 180mm fans under it, and as you see I could fit 2 120mm fans on top of it aswell, I think thats pretty good space for internal cooling.
You could also fit a 120mm radiator at the top, and use the 5.25" space aswell, so theres plenty of room for cooling.
And the graphic cards I use is 2 Nvidia GTX 280 wich is rather long.
And btw, my fans spin at 900rpm.
The CPU is a Core i7 920 @ 4.1Ghz and full load temps is at 65C.
The graphic cards is at 38C in full load (and they run at 768/1537/2520Mhz).
Huttala: 120.3 is what i'd dedicate for o/c-ed i7 only, and how about cooling sli/cf top end gpus then? And top 120.1 rad would get preheated air by bottom rad. And speaking about long gpu-s i meant 5970. 30+ cm. It will almost touch bottom fans without any rad on it. So with 5970 to place rad on bottom one has to remove original 180mm fans and dustfilters + use slim rads (which all happen to be very highfinned, so cool very bad with slow fans, and needs high rpm/noisy fans for adequate cooling).
It's not that one cannot use LC in RV02/FT02, it's just that one is relatively very limited in doing so. And if i buy case with sights on LC, why shouldn't i choose one that's more spatious, where i have to mod case less to fit more rads internal or compromise in cooling less? To not be limited in choosing PC components is feature in itself too (and what i expect from expensive bigtower).
RV02/FT02 "vertical twin" Lili X2000 actually does better for LC. Mostly because it's 5.25 bays/3.5 disk enclosures are placed different. I recall even recent project about fitting 140.4 rad in it.
That pic looks great! Has a nice surreal effect to it.
nice shot scor what kind of coolant or dye did you use?
DocGolem,you need some serious cable and wire management over there ;)
Thank's man :D
Thank You PULSAR, look here
http://www.abload.de/img/img_42693qn1.jpg
See now your shot makes me want to rethink not using died coolant. :-( I've read that any die or uv coolant can gum up over time. So I was going to go with strickly Distilled water and a kill coil. Now I don't know...........:confused:
Looking at PerPCS there are 4 different kinds of the FluidXP Blood Red. :-(
Well here is mine:
http://i292.photobucket.com/albums/m...DSC03952-1.jpg
http://i292.photobucket.com/albums/m...6/DSC03951.jpg
For info on it etc its best to look @ http://www.xtremesystems.org/forums/...45#post4283945
Is that paper over the GPU?
Following his link at the bottom for info on his build brings up this:
I edited the photos out to keep on with the image rules of the thread. :up:
And for Welsh you can always take the cooler apart and paint the cooler itself. I've seen it on a Saphire 5770 here I believe. It was which ever card has the red pinstripe down the center. The guy called it the WHITE KNIGHT. He left the red colors like they were and painted all the black white. Looked awsome. Of course with your theme being black and white.......... Although you do have the zig fan and then the blue lighting so.......
Actually it wasn't here it was Overclock.net and the guys name was "Contagion" I'm sure you can message him and get some photos of it.
