http://m6e.weebly.com/
Best viewed full screen with larger images.
Thanks Peter! :up:
http://rog.asus.com/forum/showthread...ountry=&status
Thanks Raja :toast:
Thanks Peter! :up:
Thanks Raja :toast:
Very nice !
Thanks Charleo. May be a bit too much info inside so for most people, i can summarize by saying
for the best cpu freq stability,
find the right level of VCORE/Max VCore, Input Voltage, PLL Termination Voltage and X-talk cancellation voltage.
Added Raja's link to UEFI tweaking.
Wow you guys hit it out of the park with this board you fine tuned the heck out of everything.
Thanks for the guide :up:
Lardy and Raja are too smart for their own good. :D Way too much information for the common man. ;)
thanks guys!!!
mmm sweet oc :)
HI,I have one question...I have the same motherboard...and I see you have much stronger CPU than mine(I have i9 7900x)...I was wondering,about power consumption and power connections on ours mobos...How much power draws your CPU? and do your CPU cables overheat ? I'm a bit afraid to Oc my CPU now because of those 4 pin and 8 pin connectors..
You should not be worried about cpu power draw and more about cooling the CPU. These boards were built to handle high amps, also make sure you have a decent PSU.
