Bios Mod for Asrock Conroe865PE
Hello,
I was courios about the Asrock Conroe865PE, because i can use my DDR1-Ram and my Bliss 7800GS+ with the Core 2 Duo, but due to Bios limitations the memory divider is set to 3:2 [FSB:RAM]@CL2,5, which is ok wenn you use "normal" ram, but I have 2GB Mushkin XP Redline DDR500, stable around 270Mhz@3-3-2-8.
The board itself uses the Intel 865PE chipset, also capable to run with high frequencies, so I just can't understand Asrocks rigid answer, changing the divider won't be possible. Compare it with i. e. Asus P4P800.
The divider is changeable when using a FSB800-CPU, why not at FSB1066?
The CAS Latency is also changeable when using a FSB800-CPU, why not at FSB1066?
Is there anyone who is capable of unlocking these two settings?
Thanks,
pajaa
@Mod: Is this is the wrong forum, feel free to move it to the right one.
