i guys i get my 7900GT 10 minuts ago , and i cant see cloks even with rivaturner why???
ok with coolbites it works , the XFX Extreme that i have come with 520/500 default cloks:
1 RUn 3Dmark 2005@Deafult(520/1500)
http://img297.imageshack.us/img297/8...default9nn.jpg
more testes latter
is there a new version of rivaturner that works with 7900Gt?????
nope only coolbits works. powerstrip works too.
I have no idea about it, could i ask you to run your card at 550/815 if your card is able to it? I have that card but with that clocks, it's arrived with the post, but it's 200km away from me, because i am in school. comming home next weekend, I would really like to se a result at 3ghz on that opty to and 550/815 clocks would be nice :)
Thx
/Grau
http://www.extreme-computers.pt/imagens/IMG_2369.jpg
http://www.extreme-computers.pt/imagens/IMG_2370.jpg
http://www.extreme-computers.pt/imagens/IMG_2371.jpg
Stokcooler -Default@520/1500
http://img388.imageshack.us/img388/1474/stoktemp0au.jpg
a Litle of OC:
XFX 7900GT@ (535/1560)
http://img101.imageshack.us/img101/6...55357800qk.jpg
GOESA yeh , should run 550/815 with no problems i run a Find Optimal frekuancies and i get 549/815 with Stokcooler , later run a 3dmark with that cloks , after dinner :D
Thats a pretty nice card. It's pretty amazing that your score increases by 500+ points with just pretty small overclocks on the card! From 520MHz/1.5GHz to 535MHz/1.56GHz
XFX 7900GT EXTREME @ 545/1620
http://img125.imageshack.us/img125/1...54516206mt.jpg
come on man, push that card! lol
hehehee , not so fast, slowly ill get there .
is that config giving artifacts?
Let him enjoy it :stick:
Setting it a 570-600/850-925 right away is so "easy"
out of curiosity what cooling are you running on cpu ? i have that same kind and decided to finally oc the ram to break 8.5k in '05..so what ram and wat cooling on cpu
nice scores on the 7900 btw should hit 10k EASY with a little more juice
Is not that hard to break 8.5k look at thisQuote:
Originally Posted by cMw
http://service.futuremark.com/compare?3dm05=1848107
now im testing dual core with my 7800GT and im hitting 5k @ 2006
Waiting for more results mascaras!!!
Very encouraging, I just ordered the exact same card you have from newegg literally a few minutes ago... I can't wait!
P.S. What's the default delta clock, 50?
im using watercooling on CPU and 7900GT its stokcooler , RAM im using Patriot TCCD 300Mhz cl2,5-4-3-7 1T @2.65v
CPU 24/7 config : 3ghz@1.40v (300x10//1:1-300Mhz@cl2,5-4-3-7 1T) -------------- for benching 3dmark i use 3140Mhz@1.52v (314x10 //1:1 --314Mhz@cl2,5-4-3-7 1T@2.75v)
no artefacts :D .Quote:
Originally Posted by DeToNaToR.cl
i run the Find optimal frekuencies with coolbites and get 549/815 , not bad
cant wait to a release of a rivatuner version that works with 7900GT , i prefer rivatuner than coolbites
That is truely amazing to me. My Opteron 148 needs 1.6 volts just to be SuperPi 1MB stable @ 3Ghz. Not fair !!!!!!:mad:Quote:
Originally Posted by mascaras
thx ;) and rivatuner is definnitely superiorQuote:
im thinking mines probably the same :( but it also could be my terribly low ram speed @ 217 :[Quote:
Originally Posted by Wa77x
http://img247.imageshack.us/img247/1...a1006mn.th.jpg
>> http://img421.imageshack.us/img421/6...0mhz9jk.th.jpg
and for the Pic 3305Mhz@1.66v >> http://valid.x86-secret.com/show_oc?id=64870
:D :D
A videocard is not a girl. Not sure why you would want to 'take it slow'.
Nice mascaras, and thx, nov clock that Card!
/Grau
XFX 7900GT EXTREME@550/1630-3DMark 2003
http://img88.imageshack.us/img88/3562/2k355016304dt.jpg
Thats what i am talking about :toast: How high do you think the card allows you to clock it? 570/900 perhabs?
Or 600/900 would be nice!
/Grau
well i try now xxx edition clocks and no artifacts , no problems: .
XFX 7900GT EXTREME@Cloks XXX (560/1650) stokcooler
http://img52.imageshack.us/img52/766/2k5oc0nu.jpg
sory by the cpu-z pic. its 2990Mhz like other benchs
heres the good config:
http://img95.imageshack.us/img95/1259/2k5ocnovo5xq.jpg
