Need help pushing Opteron 146 > 3Ghz
Ok, I've hit a bit of brick wall as far as my overclock is concerned.
I've had it running at 280 x 10 for about a month and everything is fine, no crashes or oddities, Counterstrike Source runs lovely and all is well except for Prime 95 which either on a blend test or small ffts will halt within a minute, SuperPI calculations are fine. The last prime stable is about 275 x 10 at 1.425 volts and about 51C under load.
I'd like to achieve the 3Ghz mark and also have my system Prime stable if possible so I can do folding.
As far as my system is concerned, during testing with my cpu to find the max fsb on a low multi, it will hit 320mhz and then anything above that and the machine gets just past the Bios screen and then reboots, regardless of the voltage. That was at 320 x 6 at 1.4 volts. Increasing the volts made no difference.
The ram is fine and is rated to 300mhz and the system was run at 310 x 9 for quite a while until I saw that it was better to not have the ram on a divider and also to try and use the higher cpu multi for better performance. This is how I arrived at the 280 x 10. I've tested my DDR 520 ram timings under mem test for a couple of hours (but not for the full 8 yet) and everything was fine with test 5.
290 x 10 at every voltage from 1.3 to to 1.6 booted into Windows but prime halted within seconds of it starting. At 1.6 volts I noticed the cpu was at 54C and not under full load so I daredn't go any further.
To be honest I'm stuck. I've seen loads of people hitting 3Ghz on air and I am hoping that my system should be good enough to hit that, I don't know what I can do to get it past where it is at the moment.
If there are any screen shots I can post which will help then please let me know and I can post them.
