The official Dual Core Opteron overclocking database (no discussion here!!)
Following lots of individual threads asking about various dual core opty steppings, I thought I'd create a thread showing the different steppings of Dual Core Opteron (socket 939) CPUs, allowing members and guests to compare different steppings/weeks.
Please only post you're steppings/clocks/screenies and in this thread. :)
Kindly use the other thread (HERE)for discussion :) .
Only post thumbnails to prevent stretching of the forum. OT Posts/Discussion will be removed by a moderator ;)
Please post you're model and steppings along with you're speeds, vCore and cooling. State which motherboard and RAM you used. Also include a screenshot of atleast 2 instances of SuperPi 32M, to show stability at you're overclocked speeds/vCore.
Click on the username to go to their post :)
Opteron 165
CCB1E 0550 VPMW
K.I.T.T. - 2799 MHz, 1.42v, Water
003 - 2750 GHz, 1.39v, air
CCWBE 0547 TPMW
Timarak - 2592 MHz, 1.37v, Air
lopri - 2799 MHz, 1.42v, air
CCBWE 0536 MPMW
dinos22 - 2700 MHz, 1.52v, air
CCBWE 0546 MPMW
demonbane23 - 2.8 GHz, 1.52v, water
NeezyDeezy - 2835 MHz, 1.47v, air
TKD - 2786 MHz, 1.48v, air
CCBWE 0550 UPMW
foodfightr - 2745 MHz, 1.53v, air
Pjotr - 2506 MHz, 1.26v, unknown cooling :stick:
CCBWE 0534 SPMW
afireinside - 2800 MHz, 1.6v, air (naked)
Repoman - 2547 MHz, 1.32v, Air
CCBWE 0551 VPMW
barrel - 2745 MHz, 1.54v, Air. Welcome to XS!! :toast:
Opteron 170
CCBWE 0543 TPMW
Budwise - 2800 MHz, 1.536v, Water (2700 MHz, 1.488v, Air)
CCBWE 0530 TPMW
rick_fx - 2850 MHz, 1.39, Air
periquitos - 2600 MHz, 1.28v, Air
akte.x - 3000 MHz, 1.60v, Water
CCBWE 0546 XPMW
eva2000 - 2900 MHz, 1.6v, water
palehorse - 2700 MHz, 1.44v, air (stability unconfirmed)
mercyless - 2800 MHz, 1.568v, water
alpha0ne - 2800 MHz, 1.48v, water
babalouj - 2750 MHz, 1.47v, water
afireinside - 2850 MHz, 1.55v, cold air
CCBWE 0550 UPMW
Pete@X - 3000 MHz, 1.58v, water
mag|c - 2800 MHz, 1.39v, air
linhvndiy - 2880 MHz, 1.52v, unknown cooling :stick:
ben805 - 3200 MHz, 1.53v, Phase change
CCB1E 0550 VPMW
iMAX - 3000 MHz, 1.5v, water
lopri - 2900 MHz, 1.52v, air
Opteron 175
CCBWE 0543 TPMW
Roliath - 2600 MHz, 1.44v, Air
Espinetenbolas - 2695 MHz, 1.58v, Air
CCBWE 0546 SPMW
the - 2955 MHz, 1.48v, Vapochill LS
Opteron 180
CCBWE 0530 TPMW
Major - 3200 MHz, 1.712v, Vapochill LS
CCBWE 0543 UPMW
xgman - 3000 MHz, 1.48v, Water (Stability unconfirmed)
FragTek - 2900 MHz, 1.68v, Water
