Crossfire in my hands now too ... ~8)
I can only run bone stock on the two cards, so here is my score:
http://service.futuremark.com/compare?3dm05=1595573
I have no idea how to overclock the two cards, I can run the overdrive utility, but it only overclocks the master card. Using ATItool, I can switch back and forth between cards and watch the temps rise on the master card only. ATItool overclocking just gives me a black screen with even just 1mhz overclock. I can use the overclocker.exe program to clock up just the single card in slot 0, but that leaves the slave out again. I was thinking of flashing the slave to the oc bios and then using the overdrive to match it's speed. That would probably get them close enough together.
