Finally i make my vgpu mod for x1300 non-pro and with slight 0.05V incrase i get extra 40mhz on core!!
Before my mod i was able 570mhz MAX on gpu but now it is 608mhz:D
Of course this is only beginning:banana:
here is screen
http://www.xtremesystems.org/forums/...1&d=1134989714
just to let you now:
- normal voltage for gpu on x1300 is 1.25V!!
- there is one resistor you need to change on pcb but it is very small! (0.5mm)
I will make howto later because i must go to work :(
