Originally Posted by thewildblue
Im really tight on RAM allocation, when the host only has 256mb I assign each VM about 32mb. If I have more then they get 64mb. The best way to do it in my view is do an install with as much ram as poss. Then patch and get ready. Change swap file size early (I only give each vm a gig of drive space). Then make copies of this VM and start up each one separately, create a new ID for each and change PC name. Then once you have the required amount ready, change the Ram down to the minimum and power em all up. If you do each one in turn with new install etc it takes ages.
The quickest way to also install is to use an ISO image instead of a cdrom. So get your original CD and create an ISO from it. Then you can also install over your network if you like saving the need to get up and put a cd in a remote machine.
Hope that helps.
