Phase Change -64c
<a href="http://img362.imageshack.us/my.php?image=150488xt.jpg" target="_blank"><img src="http://img362.imageshack.us/img362/9076/150488xt.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img312.imageshack.us/my.php?image=150519dm.jpg" target="_blank"><img src="http://img312.imageshack.us/img312/7429/150519dm.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img312.imageshack.us/my.php?image=150527wi.jpg" target="_blank"><img src="http://img312.imageshack.us/img312/8237/150527wi.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img347.imageshack.us/my.php?image=150532qr.jpg" target="_blank"><img src="http://img347.imageshack.us/img347/9976/150532qr.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img347.imageshack.us/my.php?image=150543ov.jpg" target="_blank"><img src="http://img347.imageshack.us/img347/9500/150543ov.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img137.imageshack.us/my.php?image=150555ss.jpg" target="_blank"><img src="http://img137.imageshack.us/img137/8509/150555ss.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img315.imageshack.us/my.php?image=150567fq.jpg" target="_blank"><img src="http://img315.imageshack.us/img315/3836/150567fq.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Very clean. What size compressor is that?
Compresor is Electrolux MP14FB 1/2HP.
<a href="http://img345.imageshack.us/my.php?image=img00056pv9si.jpg" target="_blank"><img src="http://img345.imageshack.us/img345/737/img00056pv9si.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
Not gonna tell us what the specs are? Gases involved etc... Other than that, its AWESOME! Good job.
The gas is r404.
I am testing 3700+ SanDiego 0525UPMW bad stepping. :cool:
http://img268.imageshack.us/img268/4894/150710ni.jpg
Nice Phase-change with very powerful compressor :toast: :woot:
How long captube ?
How about stress temps ?
Regards
Peter
Temps under full load are about -40 degrees.
I need sleevings for flexibile tube :rolleyes:
Does anyone know where can i buy it in Europe (online shop)...
tnx
Where are you located in Europe?
I buy my sleeving at Conrad electronic store. www.conrad.at
The sleeving is from Hellermann Tyton
I come from Slovenia.
tnx
Push that 3700 tell it screams :shock2: What size and how long captube did you use?
is the compressor quiet? I know my americold compressor was subsidiary of electrolux if I am not mistaken... Looking for powerful yet quiet compressor (and other than Danfoss side which is very expensive... it doesn't look too good)
Clean build.. very tidy! great job
How much superheat do you have at full load?
Great job companion.
is the compressor quiet? this electrolux is more quiet than Danfoss FR8.5CL ?
thanks for your response.
Greetings.
Captube is 0,7mm and about 2,3m long.
This compressor is not very noisy...
More pics.
<a href="http://img195.imageshack.us/my.php?image=img00375fi.jpg" target="_blank"><img src="http://img195.imageshack.us/img195/3750/img00375fi.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img339.imageshack.us/my.php?image=img00487pm.jpg" target="_blank"><img src="http://img339.imageshack.us/img339/2267/img00487pm.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
About 8 feet of captubing... sounds about right for most CPU. Since cap tubing doesn't look excessively long, that temp you are getting looks very sweet to me !!! Would love to see dual prime loaded temp on X2 with that beastie of compressor.
How quiet or loud is the compressor compared to danfoss NF9?
Some new pictures
<a href="http://img287.imageshack.us/my.php?image=img00505uz.jpg" target="_blank"><img src="http://img287.imageshack.us/img287/8826/img00505uz.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
sweet rig man i see u have not go ur sleeve yet.
No i can't find it in our country :rolleyes:
I need some good 3200+ CPU does anyone have it :)
optimal job, the compressor from 1/2HP is very good for DD;) if pits in you I would try to load the system with with the r402;)
Little changes
<a href="http://img200.imageshack.us/my.php?image=img00556vy.jpg" target="_blank"><img src="http://img200.imageshack.us/img200/9378/img00556vy.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
