1 Attachment(s)
What is this component? What does it do?
Hey guys, I need some help...
I purchased a used DFI NF2 Infinity to play with and during transit the aftermarket heatsink/fan, which was attached to the SB with thermal tape, came loose and knocked off a small component.
I found a pic of the same mobo that a member has for sale and I circled the part that fell off. I have the part and it was a clean break of two solder points on the underside.
What is this component and what does it do? Can it be re-installed, for example, if connected by two small wires between the component and the mobo? Any suggestions are appreciated.
I have not attempted to use the MB because I don't want to risk any damage.
Can one of you guys help me identify what it is that I'm dealing with?
Thanks in advance.
oh wow, so thats what knocked off
oh wow, so thats what got knocked off??? I still dont understand how that happened, Im really hoping you can just resolder that piece on there. Again my apologies.
Jeremy
