i have 2 gig kits of identical mushkin black lvl 2 pc3500 bh-5 and i want 2gb if possible for bf2. bad thing is i have to run 2t. is it worth it? or should i just run 1gb at 260mhz or so instead?
thanks
thanks
Considering you mentioned BF2, without a doubt. Trying to play BF2 on my GTX with my fast gig pack wasn't working out well at all. Not with the level of detail I was looking for. Just not enough capacity. I can assure you it's like night and day with that game. Gig might be livable with the 6600GT if you're using one, but improved none the less I'd think. If you have those long pauses, well, graphics cards don't really do that. Get some ram.
wow i cant overclock 4x512mb at all! it wount even do 220mhz 2t 2-2-2-5 3.5v!
looks like im suck with 1 gig still
Your better off for bf2 to use the 4x512 2t even at 220. That will beat the crap out od 2x512 1t 260. There's a way to properly set up you 4x512 for oc'ing. You first need to check each stick seperatly for max oc. Place the BEST stick furthest away fro cpu. then 2nd best and so on. I personaly havent done it b/c i use 2x1024 1T :) but have read about it here at xs. Use the search, if i find it i will post the link.
What chip are you running, stealth? I'm running a Winchester 3000+ 0447 CBBHD and I can't get 4x512mb OCZ Gold BH5 to do 2-2-2-5 2T, or even 2-3-3-5/2-3-3-6.
I'm stuck running it at 2.5-3-3-6 2T with 4 sticks, and I'm pretty sure it's the memory controller on the cpu.
Quite certain it's not the DFI NF4 UltraD.
2x512 either kit runs 2-2-2-5 1T 230fsb 3.0v.
I do notice improvements even at the slower timings with 4x512, however, both in load times and how much my system will lag after exiting games, etc.
WOWOWOWOW!!! thats all i can say!
i put 4x512mb in and loaded optimized defaults. that means EVERYTHING was running stock (except VC) and ram timings were CRAPPY! not even 2-2-2-5! with 2gb i never went below 49fps and i played a game a Strike At Karkland, i got second place by 2 points! i almost ALWAYS come in almost last at that map for some reason! i never did good! it never lagged at all! i am happy :) :)
i may look into actually overclocking this ram and making 4x512mb. i want 2x1gb but the timings would suck for records, and i cant afford to buy that and keep another 2x512mb kit around for benching.
im on a san diego 3700+. why cant these things run 1t 4x512? i thought thats the advantage the rev E chips had?
It's trick finding just the right Dimm's for each stick !! Makes a HUGE difference in OCing.Quote:
Originally Posted by stealth17
you will need to teast each stick individually and then place them in them dimm's as described in this thread: http://www.xtremesystems.org/forums/...ad.php?t=66968
i gatta go mow some grass then ill come back and do come overclocking. i think part of my problem was that i had bank interleave on :rolleyes:Quote:
Originally Posted by Major
And you should make everything possible to keep it that way, ON.Quote:
It's because of bank interleave that going from 2x512 1T to 4x512 2T don't hurt performance too much (if it hurts it at all).
You should follow the advice to try the sticks in different slots. But spare yourself from trying each stick individually to put the best in the slot furthest away from the cpu and the worst in the slot closer to the cpu. This method appears to work well with two sticks, but not with four (from my own experience). The problem is that (with the DFI NF4) some memories don't like yellow slots and others don't like orange slots. This is another factor that adds to the fact that generally sltos closer to the cpu are stronger.
For instance, for TCCD memory that like orange slots, the 3rd slot from the cpu (2nd orange) may be stronger than the 2nd slot (1st yellow).
Besides that you may have one or more bad slots in random positions (not necessarilly further away from the cpu) due to problems in the manufacturing process.
It's boring, but to make sure you have the sticks in the optimum place, you have to try all the 24 combinations (I've tried 16 I believe, before quiting). Good luck.
i had big problems getting my 4x512mb stable. but i think it works now:Quote:
255MHz 3.4v (vx4k)
http://img139.imageshack.us/img139/7383/stable9lp.jpg
Do you have the jumper on the 5V line?Quote:
Originally Posted by Der_KHAN
Isn't the pwm-ic hotte(r with 4sticks?
I have 4sticks of utt to,bid I was scrared to use the 5v line.
of course i run it off the 5v line. dunno if the pwm is hotter - i have a fan cooling it and as long its below 110°C its fineQuote:
max async 9
read preamble 7.5x
did those worth better with 4x512mb than 2x512mb?
what drive strenghts you using?
Ive seen someone with Gskills (2) and Redlines (2) running 250 @ 2-2-2 easily.... The only loss you get is 2T timing.Quote:
a64tweaker doesnt read them correctly. heres a pic from the bios:Quote:
http://img326.imageshack.us/img326/7832/stable8xx.jpg
(as mentioned at 255MHz/3.4V)
i think some of these values can be tightened but i havent found the time to tweak em all, cuz im playing bf2 all the time. :D
i had occasional crashes at first but with these settings they seem to be gone
i can run wow and bf2 stable for hours and i get 30.4s in SuperPI 1.4, with 2x512 and 1T it was 28.7s i believe
Ive got no problem with 2 kits of redline HP3200 doing 4 x 512 253Mhz 2-2-2-5 @ 3.1v, memtest, games, 3dmark stable!
Working on a new review - here are some results so far showing 4 sticks vs 2 and 1T vs 2T - not much to see in real world results....the slight loss in performance is worth the smoothness you pick up in game.
Btw the OCZ PC4800 results the CPU was 312 1:1 so 2.808 Ghz. The Mushkin results are at 2.75 Ghz (275 x 10). I'll try and get the PC4800 updated at 305 1:1 to get comparison results at 2.75 Ghz.
http://www.3dxtreme.net/other/ontap/2gb/1tvs2t.jpg
Im not using bh-5 but with the ballistix I am using I am able to run 260 fsb 1:1 without issues and low volts. I do know if I push it higher my memory controller doesnt care for it. But as for bf2 ya 2 gigs makes night and day results. I place top 3 with 2 gigs and near last with 1 gig.
having a hell of a time with this 4x512mb nonsense. i think what i will do is sell the extra 2x512mb and get 2x1gb for 24/7 then just run the 2x512mb for benching. in 3dmark03, is there a big difference in 512mb vs 1gb? if not, i may sell all 512mb sticks and save some more money and get 2x256mb for benching. it usually overclocks higher too :)
plz help. i almost smashed every peice of computer equiptment when this keep crashing at stock 4x512mb in bf2 :(
thanks
Is it a fact that you must run 2T with 4x512? Cause I just literally popped in two more stick like an hour ago and even when I select 2T in the BIOS, it boots 1T no matter what.
I've confirmed that i'm running 1T cause I can easily switch back and forth wth A64 Tweaker and see my SuperPi results. I'm actually getting .4 faster in 1Million now with 4x512 with all the exact same timings including 1T.
I ran 2 separate instances of Memtest (windows version) for about 30 minutes with no errors....this is weirding me out.
Aren't I supposed to be running 2T? Setup is sk8v, opteron 252 (E4), and 4x512 of corsair cmx512re-3500llpt doing 13x217 2-3-2-6 1T @ 2.7v.
Mine wont even post with 4 sticks and 1T enabled.Quote:
Originally Posted by drcrawn
Maybe the opterons can? not sure...
run sandra memory bandwidth tests and see what you get...
Originally Posted by dnottis
Will do, but im off a fairly fresh install so I gotta download everything. I did just play Halo for just over an hour, totally stable :cool: . I'll check back with screens. Would this be a first? Can anyone else get 4x512 1T stable on a new E revision?
mine is E rev....cant do 1t 4x512mb.
bumpQuote:
Originally Posted by me
Call me a lucky son of a &^*%!.
Sandra reports everything at 2T :stick: . I'm using A64T to switch, but the board will not boot @2T no matter what, lol. BTW, this would not run @2.6v, so I went to 2.7vdimm and manually changed 2T timing to "enable" in bios, and thats when I realized it was booting 1T instead. Went back and tried 2T setting in bios to "auto" and still I get 1T. Pretty funny actually. Best memory controller ever? lmao
http://img320.imageshack.us/img320/1917/1t3rm.jpg
http://img320.imageshack.us/img320/1001/2t8ab.jpg
SPI 1M test 1T, 2T with a all those things open so take with grain of salt...
http://img175.imageshack.us/img175/5681/pi1t4ey.jpg
http://img175.imageshack.us/img175/2060/pi2t6lm.jpg
Don't know what to say really i'm shocked, but I'm not complaining :banana: .
try the settings i posted above and increase your vdimm 0.1v over the value u run with 2x512mb.Quote:
if this doesnt work try max async 9.0ns and read preamble 7.0ns
