PCMark05 has hit, let's see what you got :banana:
Download mirrors here: http://www.futuremark.com/download/?pcmark05.shtml
BTW Requires WM10 installed, and WM9 Encoder: http://www.microsoft.com/windows/win...r/default.aspx
http://i4.photobucket.com/albums/y132/Magnj/pcm5.jpg
Detailed Test Results
System Test Suite
HDD - XP Startup 8.06 MB/s
Physics and 3D 170.53 FPS
Transparent Windows 1007.91 Windows/s
3D - Pixel Shader 132.9 FPS
Web Page Rendering 3.13 Pages/s
File Decryption 43.84 MB/s
Graphics Memory - 64 Lines 1428.68 FPS
HDD - General Usage 5.4 MB/s
Multithreaded Test 1 / Audio Compression 1447.71 KB/s
Multithreaded Test 1 / Video Encoding 179.6 KB/s
Multithreaded Test 2 / Text Edit 87.26 Pages/s
Multithreaded Test 2 / Image Decompression 12.34 MPixels/s
Multithreaded Test 3 / File Compression 2.53 MB/s
Multithreaded Test 3 / File Encryption 11.84 MB/s
Multithreaded Test 3 / HDD - Virus Scan 23.84 MB/s
Multithreaded Test 3 / Memory Latency - Random 16 MB 12.02 MAccesses/s
Don't laugh, this is my PC at work :p:
http://service.futuremark.com/compare?pcm05=617
http://xtremesystems.org/forums/atta...id=33265&stc=1
Mine:
(I need some CD-KEY :p: )
http://rotter.name/User_files/nor/42c267a50878d866.jpg
Dothan b1 2mb ch' @ 133*18
Aopen Gmem-LFS i855
256*2 Micron 2.5-2-2-5
X800 pro VIVO @ 16pp 520/550
5451
well here's where i am... so far
Pcmark05 = 4,787
http://service.futuremark.com/compare?pcm05=9867
http://www.fileshosts.com/DFI/NF4_SL...09_4787_tn.jpg
http://service.futuremark.com/compare?pcm05=3351
Not sure how I am still holding the #2 spot.
huh i thought you already achieved 9+ k in pcmark05 ???Quote:
Originally Posted by FUGGER
^ PCMark04 ?
Mine is 4747.
Here's the link
SamHughe
SamHughe, Welcome to XS!
At your clock speed on A64(2840MHz) and the high speed low latency memory you are scoring about the same thing as someone with P4 EE at 3200MHz. That is insane!Quote:
Originally Posted by eva2000
A 2800MHz A64 should give an EE at 4.2GHz a run for its money.
This benchmark is bogus to say the least. When A64 X2 users shattered the PCMARK 04, so the only thing they could do to save the intel users(after they clock the CPUs to the limit without catching up) is to re-compile the code and name it PCMARK05.
WHAT A BOGUS BENCHMARK.
I learnt Sandra 2005 was recompile with an intel compiler and that's why we are seeing Prescott having better scores on them. It's a SHAME on all these people.
Thanks! It is good to be here. Looks like there are alot of people here who know what they are doing.Quote:
SamHughe
you know why,Quote:
Originally Posted by agenda2005
1. multi-threaded tests you'd win easily and boosts P4 systems
2. the hdd related tests skew the results i.e. raid 0 will give you at least 200+ extra pts
using my spreadsheet calculator http://i4memory.com/showthread.php?t=787
if i raid 0 my system my HDD Virus scan test will jump from 15.41MB/s to 32MB/s which equates to jump from 4787 to 5010! :eek:
And here is mine: 6118... The XE is FAASSST with this!
http://service.futuremark.com/compare?pcm05=1321
Just watercooled. My RAM sucks so I was limited to 214 mhz at 3 4 4 8......
I'll try a little more later tonight.
FUGGER, how do you know you have #2? Anyway to see it?
Check the orb, project search under PCMark2005
http://service.futuremark.com/servle.../projectsearch
Thank FUGGER!!!
Its nice to compete in a new Benchmark!!! 2morrow i will make a RAID setup to see the difference!!! I will keep you informed!
