Dual T.E.C. my journey to -37℃(39pics)
HOWLY CRAP
nice dude !!!
normaly you should pass 3ghz with a good cpu :toast:
That's absolutely amazing :slobber:
true craftsmanship :up:
and I love the rabit :D makes for some nice contrast with all the cats roaming around at XS ;)
omg, thats insane !! :eek:
looks really tight :up:
O-M-F-G
XTREME COOLING!
Not so xtreme results :( Get a better CPU :D
Are those 226 watt TECs? How does a single fan rad keep them both cool?
a single fan rad is enough to keep them both cool
Wow, that is soo cool. You should try it with a bigger rad to see if you get any cooler temps. You should get a better clocker under that and see what temps you can acheive. BTW, what power supply is that.
very cool. How much did it cost ya
What kind of water mixture did u use?
I used 1/6 Anti-freeze. Freeze temperature was -9°. I could add more but I have a huge reservoir, maybe your adds are better then anti-freeze.
Man, that looks like a company massed produced that thing. Mucho props on the awesome craftsmenship. lol I can never come up with anything even close to as how well put together that thing is.
very cool indeed. clean and extreme :toast:
Awesome work bro but get some arctic silver 5 and you will drop even lower. Its worth the money get a 12g tube and you'll be rockin...
very nice bro :) I think that if you try to cool better your pelts you will have better temps. Can you post a screenshot running prime to see how it holds at full load?
i didn't mix anything in the water.
Why would he be worried about freeze temperature of his water? He is not running chilled water he is using the water to chill the hot sides of the tec's. That means his water will be a very high temp and not a very low one.
sjx just to give you an idea with my setup dropped 30 degrees c by switching from the cheap ass white heat paste to artic silver 5. couldn't believe it dropped that much myself but with your sweet setup there you should spend the extra $ it will be worth it.
30C :confused:
I think you had a bad sink contact! :stick:
always a possibility but have had it apart many times and did everything the same when it was pulled apart the paste was spread evenly on all surfaces so i doubt it...
jesus dude, I think thats the first time I was impressed with how much effort someone put into Pelt Hardware :D
nice job man, you make pelts looks sexy heh
Yup, I know :D
Somehow i mixed up 2 threads :confused:
i'll try it, but it's not cheap, worth 140rmb in china
and what's your temp. then?
on an NF7 ser 2 idles -1c and load 6c
Looks very good!! Very professionaly made.
sjx-qd, are you by any chance from Hong Kong or China?
china mainland
