Important ! Read if You have problems with G.SKILL LA.....!!!
:slobber: This is unbelievable - I always had blue screens at higher HTTs and the RAM seemed to be unstable - but my A-DATA was working fine so I didn't understand it and tried to find out - I wanted to be sure why and now I know:
1) I always tried with the usual Vdimm of 2,8 - 2,85 - 2,9 because I thought that is the right range fot TCCD and my A-DATA running best with 2,9.
2) That was wrong, G.Skill LA is extremly sensetive to too much voltage, I set the Vdimm in the BIOS to AUTO and it gave me 2,7.
3) I thought this would never work - but:
http://img221.exs.cx/img221/1904/gskill270bs.jpg
4) STABLE - no problems anymore - 2 x 256 G.SKILL LA at only 2,7 Vdimm !!!
5) So poeple if You have problems with the G.SKILL try to drop the Vdimm !!!
:toast:
