Mounting isn't done yet but is done through a 1/2 inch thick PVC ring which is supported by the copper ridge on the pipe. The container is around 14 inches tall and will have 3/4 inch closed cell neoprene insulation. The contact block is a chilly1 spiral block like the ones inside my phasechange evaporators. I do have GPU coolers with the same dimentions but these have my new mounting system with a poly ring around the end of the block for mounting.
http://www.xtremesystems.org/forums/...id=21956&stc=1
http://www.xtremesystems.org/forums/...chmentid=21947
http://www.xtremesystems.org/forums/...id=21948&stc=1
http://www.xtremesystems.org/forums/...id=21949&stc=1
http://www.xtremesystems.org/forums/...id=21950&stc=1
