I have heared that this mobo and this memory doesn't really "like" each other... is it right ???
Any problems with that "mary" ???
Any bad issues ???
Please help me because I"m thinking of buying this stuff...
Thanks,
Any bad issues ???
Thanks,
Doesn't anybody know anything about that ???
May I buy this motherboard with this memory without any problem ???
never heard of pc5400 unless your talking ddr2. a64s do not support ddr2, but you cant go wrong with most tccd ram :) However you gotta hope you got a good ondie controller if you want 1:1
Hummm...
ASUS P5AD2-E Premium motherboard is not for A64... it's for P4 LGA 775...
I have the combo you describe in your topic and my system is rebooting @ 4.0 ghz whenever i put some load on it. i thought it was the mobo but now i think its cos of the powersupply. Im getting a new power supply unit on monday with the 24pins plug instead of the 20 pins that should fix my problem hopefully.
Very good news you're giving me !!!
I know for you these news may not have been as good as that bur for me it's really a good news, because I have ordered this bundle and I was beginning to become sad with that situation, thinking that I haven't made a good choice...
I got the 24 pins Tagan 480 watt psu and its still unstable :(
so its deffinately the instability problems between corsair memory and asus mobo :(
I have the P5AD2-E Premium and Corsair TWIN2X1024-5400C4PRO with horrible problems!
Firstly, my CPU throttles when I overclock (from ~2,8 to about 3,2-3,3) (checking with Panopsys ThrottleWatch, http://www.panopsys.com/throttlewatch.htm). My IDLE temp is 55C with an 7700CU and its mouted as it should be!
Secondly, my FSB jumps up and down from about 100 MHz to whatever I set in BIOS, very very strange. The POST also take very long time, the computer looks for harddrives for about 1 minute until it continues to boot.
I cant get the WiFi to work, I get "Unable to connect to the wireless lan card. The tray icon will be loaded once the card is inserted" when I try sto configure the WiFi. The funny however is that I can see the icon down in the systray, and in the device manager I can see the device and the drivers seems to be installed fine.
My other hardware,
P4 2,8GHz (D0-stepping)
PowerColor X800XT PCIe
Maxtor Diamondmax 300GB SATA
Bios 1003b7
Plextor 712SA
Well, don't buy this motherboard, I'm going back to my old Gigabyte 915P...
Corsair can suck my balls i just ordered Crucial Ballistix DDR2
Installed my old Gigabyte 8GPNXP Duo and everything works fine. Nor do I have any problems with ABIT AA8XE Fatal1ty or Gigabyte 8AENXP-D. So personally I think the problem is with ASUS, not Corsair.
So ASUS is the one who can suck my balls! ;)
Operator Headspace.....is your problem....Not ASUSQuote:
Originally Posted by nizenco
I ran into similar problems but I was able to work them out on my own and no longer have any problems what so ever....
Maybe a bit more patience and tinkering will get you out on top.....
Try reflashing the bios,
Instead of using the ASUS WiFi drivers...use Microsofts more updated drivers through windows update....for both the Wifi and the LAN....
Learn your bios....!!!!
Your problems are not difficult to fix....
SKI
yeah what djski said. yours has nothing to do with the Asus mobo and Corsair ram.
I dont have problems with Corsair on stock speeds either, works perfect.
However at 4.0 ghz its giving me problems thats why im changing to Crucial :X it should work perfect then. I'll keep you people updated.
Originally Posted by dj_ski69
Well, if they are so simple to fix, why can nobody that I've talked to help me? I've been in contact with ASUS R&D i Taiwan and Holland, I've gotten tons of different BIOSes (latest from 23/12), and I get the same symptoms with all of them.
Yes, more patience, I've spent roughly 50+ hours to try to get this board working… Took my old Gigabyte, plugged it in, after 5 minutes of work it was up an running without any problems… My personal opinion is that no board should take this long to set up, no matter what.
My personally opinion is that either is my board defect (the most probable cause), or ASUS have release a half finished product.
And if you have sorted out similar problems, could you please describe how you managed to do that?
can you please mail me that latest bios to corleonee@gmail.com.
I'd really REALLY appreciate it m8 thanks in advance ! :toast:
Asus P5AD2 Premium and 5400s
Some interesting things have come out of that thread, which Ram Guy (Corsair's official rep) stickied in their forums:
So far there's 2 or 3 posters there that have switched to different PSUs and that's cleared up their problems. Nowhere near enough to say for sure that that specific PSU is the problem (could be just coincidence), however if you have a spare PSU that's hefty enough for it, it may be worth a quick swap to test it.Quote:
Originally Posted by drheim @ House of Help's Official Corsair Memory Support Forum
Also, are you guys underclocking the memory to match the system's FSB, or running it async, or just straight trying to bump up the FSB to the speed of the memory?Quote:
Originally Posted by oddlycalm @ same site as above
Sorry mate, I'm not allowed to forward it, the latest you can get as of now are the 1003b7 (which you probably already know).Quote:
Originally Posted by Corleonee
And I'm using a Antec Neopower 480W (regardin the post above with PSU issues). Will try with a TruePower 550W and Phantom 350W tomorrow.
Hey nicenzo i found the solution to your problems however its confidential.
sorry
pfff SS'er
I got the Crucial Ballistix and i am now rockstable @ 4.1 GHZ !
With the corsair i couldnt go stable over 3.9 ghz :S
Hardocp has a review on the Asus P5AD2-E + Corsair ram. They couldnt get it stable over 3.9 ghz either
I have 1gb of OCZ PC4300 3-2-2-8 Platinum and I'm having issues with it posting properly and running stable. Asus suggested that I buy different memory for my P5AD2-E. :)
I'd say 60% of the time when my system posts, it hangs right after it displays the memory count. Or it proceeds to operate extremely slowly and will misdetect the drives in my RAID0 array.
They offered me no bios updates, nothing to change. Simply to get different memory. I know it's not Corsair, but I'm kind of in the same boat with some of the best DDR2 on the market.
i've have this mobo and 2x512mb ocz pc2 5400 4-4-4-8, and i don't have any problems...
Hummm,I was thinking of getting the mushkin pack 2x512 pc5300 along with this MOBO, does anyone know of any issues regarding this 2 components? After reading this thread I got a little "scared" oh this MOBO...
With the latest Beta Bios Version 1003.011 does the momory situation looks better ???
Can anybody with Corsair memory test it ???
Would be easier if you all posted your exact setting (dual cpu-z screenie sure would be of some help).
I don't have an E-version of the board but I experienced strange things...
The weirdest thing was that at 4-5-5-15 timings, I couldn't overclock...
i560/P5AD2 Premium/X800XT/Corsair TWIN2X512-5400C4 - combi
So I first switched to fsb200/DDR600 and tightened the timings (2.1V vDimm)...
4-4-3-11 gave me best performance (memtest and Everest)...
After that, I switched to fsb200/DDR533...
Upped the fsb somewhat and this is what I've got with the memory people here seem to hate:
fsb 233 / DDR622
--> rockstable, running 2*f@h 100% 24/7, after two days, cpu is still not throttling...
Actually, I was thinking to get me the E-version and some OCZ-sticks, but will it help me that much?
Or is it simply the guys at ASUS who are not doing their homework???
btw, I'm using bios 1010.004 beta on this P5AD2 Premium...
@DJ_SKY69: could you post some working links in your signature (3Dmark-stuff, I'd like to see the settings you used :toast: )
Hi!
My System: P5AD2-E Premium 1003 Bios, Intel 560j 3,60 GHz @ 3,90 GHz, 2x Corsair TwinX 5400C4 1024 MB runnig with FSB 278 Ram 576 4-3-3-8 Timings and 1.90 Volt. With 2.10 Volt and 4-4-4-12 I can get the Corsair stable at about 710 MHz, but cant run the board with a higher FSB than 256 and use the 3:4 divider. The board sets the ram timings to 4-4-3-8 all the time.
Hope this helps?!
Thuroughly tested P5AD2-E and Corsair 5400XMS PRO
1002 and 1003 bios up to 2.2v DDR780 or so
This combo works fine
