Gskill DDR620 on DFI LP UT
Got my 1GB PC4400 512MB 2.5-3-3-7 / 2-2-2-5 kit and tested it on the DFI.
lets see what it does on a Single channel platform.
This mem does NOT WORK with the DFI with 2 dimms inserted, I get 10K errors in memtest #5.
[UPDATE]
I tested with a other 3400+ CPU and now with Drv Strenght bootable at 1, i come alot further with this mem. 275Mhz 2.5-3-3-5 @2.6v.
I have a strong feeling that is has to do with the Drv Strenght.
[/UPDATE]
I ask jack from Gskill, he said it is a known compatible problem with single channel controllers :(
So only 1 dimm inserted you will get the max. mem stability.
Max stable is 265MHz 2.5-3-3-5 1T with 2 dimms inserted.
with 1 dimm
2.7v
10/5 bios
Skew value = 128
Drv strenght = 1
4b burst enabled
All with 1T CPC.
http://www.xs4all.nl/~famchow/Memory...ill_pc4400.jpg
http://www.xs4all.nl/~famchow/Memory...st_module1.jpg
http://www.xs4all.nl/~famchow/Memory...400/DDR600.JPG
http://www.xs4all.nl/~famchow/Memory...400/DDR610.JPG
http://www.xs4all.nl/~famchow/Memory...610_sandra.JPG
with 2 dimms
2.7v
10/5 bios
Skew value = 128
Drv strenght = 1
4b burst disabled
1T CPC.
http://www.xs4all.nl/~famchow/Memory...MHz_1024MB.JPG
