Just got them running 5 mins ago..So far so good!:D
Attachment 131607
Attachment 131607
stop flaunting your Ferrari movieman..some of us can only drive regular cars..:p
Rock it Dave !! :)
Awsome Dave :clap: ! Stock cooling or aftermarket ? Temperatures idle and full load ? I Like that L3 cache :yepp: , enjoy it bro :up:
show off
that cpu usage history looks ridiculous :D
These are impressing the hell out of me so far..Low temps, huge computational power.
You could run these in 90F room and they wouldn't overheat!
Dr's appt tomorrow and then will see if they will do higher BCLK and if the Corsairs will work with them..
Stay tuned! :D
Forgot, taskmgr with WCG running:
Attachment 131612
run wprime pls T.T
That boincmanager looks...wrong.
So, when are You going to stop kidding around and linux it?
When finally on linux... please run geekbench 3 :D
Wowza! Impressive cpu's as usual MovieMan
This monster will help with super computer week! :up:
run XTU :) and send me result file ;) I kid I kid
I left the machine running WCG when I went to bed.
Just looked and the machines average is going up like the flight path of a Saturn 5 rocket! :D
41s... not bad at all. Just 11 seconds to go :D
Winderz is jest fine. Don't need no stinkin' penguins! :p:
You're traveling through another dimension -- a dimension not only of sight and sound but of mind. A journey into a wondrous land whose boundaries are that of imagination...... You unlock this door with the key of imagination. Beyond it is another dimension: a dimension of sound, a dimension of sight, a dimension of mind. You're moving into a land of both shadow and substance, of things and ideas. You've just crossed over into... the Twilight Zone .....
.....and in a while those 4way and 8way 15core solutions will be available..... Gonna need a bigger version of realtemp.
http://stats.free-dc.org/stats.php?p...hostid=2326979
Architecture: GenuineIntel Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz [Family 6 Model 62 Stepping 4]
OS Details: Microsoft Windows 7 Ultimate x64 Edition, Service Pack 1, (06.01.7601.00) <- this is not OK, OK?
Number of CPU's: 48
:trollface:
