Asrock Z87E-ITX seems to have one big difference in the layout compared to Z77E-ITX: The socket have moved away from the PCIe slot.
http://www.computerbase.de/bildstrecke/47857/5/
Thats good news. I love my Z77E-ITX but it is a bit of a pain having the socket right up against the pcie slot.
LOL I was hoping to post some more news from CeBIT, but I guess the board makers are focusing on larger form factors as usual.
My Z77E-ITX is great, so I'll keep an eye open for the Z87E-ITX during the next few months.
ITX is just wonderful. Looks like a nice platform. Finally, we can run large heatsinks again!
I wonder if they can push the OC envelope like Asus did w/ their deluxe board.
What case is that?! :shocked:
Oh I forgot, it's ASRocks own case, too big if you're asking me, not interested. What's the point with using a riser if it doesn't make the case thinner?:shrug:
http://www.computerbase.de/news/2013...i-itx-platine/
Translation: http://translate.google.com/translat...itx-platine%2F
Did you see the first pic?
In the corresponding article it says the case should be ready for release until Computex.
Have you guys seen the awesome ITX case Prava created a thread about?
http://www.xtremesystems.org/forums/...-the-SFF-realm.
You gonna put hardware in there that will use in excess of 750W? Good luck with that ;)
No, I'd like to use a 165 mm modular PSU, which is common these days. Good luck finding a 140 mm fully modular PSU, Gold or Platinum, that's also quiet.. (Silverstone Strider ST55F-G may be the only candidate, dunno if it's quiet tho.)
There's a reason for why they used a 4 year old, 80Plus Bronze, 125 mm Nexus PSU in those renderings: it's unbelievably short and gives the impression that there's more room in the case than it actually is.
*yawn* boring. Mini-ITX is soo 2009.
I want smaller form factors to quickly displace the larger, like intels NUC but even smaller....more like the macbook air mainboard, and even the intel medfield smartphone form factors....but with haswell inside.
I think the first problem would be that it does not seem to support 140mm modular PSU's. I am sure there exists decent 140mm PSU's without spectacle.
To be honest though, even if you could place a 100% modular PSU you would still have a lot of clutter with cables. Given that they usually are quite long, even the "short-cable" kit's will be excessive.
So it kinda boils down to some hard modding of the PSU's cabling, which is quite easy, but time-consuming.
With modular cables you're able to shorten the cables without voiding the warranty, and that's why I want it. I thought it was obvious.
But if it doesn't fit then there's no point I guess.
Here's a better pic of the Z87E-ITX.
I see six SATA ports, nice.
http://pc.nikkeibp.co.jp/article/new...2/13_px400.jpg
You're right, did not consider this.
And I have nothing but respect for keeping the guarantee on whatever product the person buys, on the other hand 14cm PSU's aren't very expensive and you can always let it run a bit before the modification is done. It's not exactly fool proof though...
Then again I am personally not deterred by warranty stickers, this is a hobby after all and the stakes are quite low =)
Nice board indeed, here you can find some close up pictures. The system designed by BMW is not bad either :)
Not really. It depends on whether you plan to use a long VGA or not. Still, you can use an SFX psu and be done with it, its not like you need 500W in there.
Modular won't fit, because the connectors would start by the VGA and there isn't enough space: you have to use either an SFX psu (modular or not, no problem), a short non-modular 140 mm psu... or a very very short psu.
Still I have no idea why you want an efficient power supply in the first place. I want a power supply that has very good voltage stability and ripple suppresion, couldn't care less about efficiency. IMO, gold, platinum and all that are VERY overrated.
Can solve all those problems with a M1 :D
-PB
problem with M1 is thta its still too too big. this is more like it.
Well if I didn't consider having a graphics card, then the quest for a good case wouldn't be that hard, right? ;)
I'm going to use a graphics card, and by the looks of the pics I'd need a card shorter than maybe 200 mm to make room for a longer PSU.
There's simply not enough room.
I want that as well, but it has to be quiet, and if I'm getting a new PSU there no point in buying old tech.
It's not really hard to find a PSU with quality output these days..
I want to put my GTX690 in an M1. I guess manufacturers need to work on making shorter PSUs :)
M1 is big-ish, but it uses the space very efficiently. In terms of xtreme performance, where you will be able to fit a large CPU-cooler, 3-slot graphic card and even tiny watercooling(external) if you feel for it.
PSU choice is limited, but you can do that with products available today. *With the drawbacks Mats and I was arguing about. ^^
Don't you think that defeats it's compact form a bit?
How about:
PCI-E extender than enabled you to put dual slot graphic-cards one slot closer to the bottom.
