Originally Posted by
sin0822
what PCi-E 3.0 transceiver problems? i heard their only problem is that they didn't have time to get it PCISIG certified?
I heard 200blck but it is just a rumor:p:. I think maybe they will seem as if they OC higher, beucase most people havemn't bought CPus either b/c they are sold out or just too expensive. Most results on are ES and if retails haven't thought us anything is that they are clocking better than most ES CPUs, just not many people have them. I mean look at the WR is sitting on top of basically as ES submissions and some retails that are very high up like Loud's. BTW Newegg is not getting more until C2, it isn't just that they are out of stock for a little while, Intel ran out of CPUs which was part of the plan. I remember massman put a post up saying showing some high 167blck on a CPU, which everyone thought was C2, idk if it was C2, but it used the MSi bangbang and it has a modified clock gen to allow higher BLCk. it really idk what you really want 1.67 multiplier at that high for, other than maybe it could be a sweet spot, but BLCk dividers are good for memory speed, and i would think 1.25 and 24x and 107blck would be enough for most, but using 1.67 is nice too. if All C2 CPUs have better BLCk that would be nice, but i don't think they will. i think maybe their silicon quality might be higher, maybe intel has worked on the leakage to lower some temps. Intel needs to start working on leakage tho, for real as if they don't on the next CPU they release it will be crazy lol.
