Hey guys
New benchmark prog out to test our HW.
Link http://downloads.guru3d.com/x264-FHD...load-2825.html
Please post scores once you have some. Mine will follow shortly.
Hey guys
fun
i will share with my friend
Score was with first run using my 24/7 clock with apps in background. Will squeeze more.
There's another thread on Guru and BD is really doing well compared to Intel chips. Just show that BD shines with right software.
Tried it out for fun :)
http://i119.photobucket.com/albums/o...bench-24-7.png
Cool thx for the soft...
it's repost we already have a thread for this at benchmark section
http://www.xtremesystems.org/forums/....1-%2864bit%29
Well, this is the new version supporting new instruction set.
Plus, its great for us AMD folk to test our new BD toys ;)
Here's my piggy:
http://i40.tinypic.com/2jhd0m.jpg
Well, kull, u will be glad to know that your piggy is one par with a 2600k at similar clocks ;)
nice benchmark, it support AVX etc?
It uses AVX, XOP AND FMA4. I'm not sure how much benefit it is bringing though.Quote:
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX XOP FMA4 SSEMisalign LZCNT
http://forum.doom9.org/showthread.php?t=162725
I got 25 FPS at 4.7.
X2-550 (C2) @ 206x17 X4, All default settings, Air, 24/7 setup
encoded 2500 frames, 12.20 fps, 22391.13 kb/s
http://img838.imageshack.us/img838/7981/x2641.th.png
Do you need a CPU-Z screen shot before you include my score?
Here's a quick test of this bench on my 8120 (yes, I pulled the wonky 8150 :rolleyes:)
http://i30.photobucket.com/albums/c3...X264_25fps.png
I tweaked a little, but it looks like this bench likes tight mem timings more than higher cores (or high mem frequency).
My 8gb kit is good at freq, but not so much at tight timings...
Thanks for posting this bench mR Yellow!
Encoding is without a doubt my most power hungry real world use...
This'll help me dial it in! :up:
Wow... Imagine that, someone who uses an FX for what it's good at instead of worrying about online reviews conserning gaming. :p:
Here's a run with my daily settings:
http://img.photobucket.com/albums/v6.../x264small.png
Here is my run, This was on standard water, no winter cooling.
25.73fps
FX 8120
4.8ghz 1.52v - 2.6ghz NB 1.3v
800mhz (1600mhz) 2x2GB DDR3 7.8.7.21 32
Asus CHVF, B-9921
http://3800z24.info/CHVF/4.8-2.6-X264-Bench.jpg
Here's a new one from me, just to keep our friend ReKc0lNu busy. :p:
http://img.photobucket.com/albums/v6...26426small.png
Watercooled, Windows 7 Ultimate 64 bit.
I think what this benchmark shows is that memory and cpu performance is good with BD.
I see guys with 2600k (OC'ed) getting similar scores. And we know that mem bw is better on intel but BD has improved it.
Some light WC system - Antec Kuhler 920
http://www.abload.de/img/resultdcp2k.png
No extra tweaking cause RAM wont go beyond 2420 MHz. CPU has limit about 4970-4980 MHz for this benchmark with 1,5 V (Weak PSU - 600W OEM Seasonic + high temps).
