***ASUS Rampage IV Extreme Owners Thread***
This is the master thread to list RIVE reviews, BIOS updates and so on.
http://images.hardwarecanucks.com/im...conclusion.jpg
Board reviews:
http://www.hardwarecanucks.com/forum...rd-review.html
http://www.overclockers.com/asus-rampage-iv-extreme
http://www.overclock3d.net/reviews/c...treme_review/1
http://www.tweaktown.com/reviews/441...iew/index.html
http://www.guru3d.com/article/asus-r...xtreme-review/
BIOS:
1305 Improve system stability, improve memory compatibility, enhance compatibility with some USB devices, support new CPUs
0018 Updates some pcie codes, open range off vga core to -222
1202 Improve system stability, improve memory compatibility, enhance compatibility with some USB devices, fix PCIEx16 VGA card HD 7970 cannot be detected when the temperature of VGA less than -40.
0016 Based on 0015 but adds 5v and 5.5v options to mos volt control
0013 Improves DRAM OC
1201 Minor fix of dual gpu VGA detection bug in bios's GPU/DIMM post screeen.
1103 Improves High Frequency DRAM Compatibility, Improves Peripheral Compatibility
0006B
1101 Improves system stability, official BIOS
0005B Improves CPU Level up for new cpus, improves stability for 7970 when 7970 under LN2
0003B
0002B Adds internal pll over-voltage option, improves stability for 7970 when 7970 under LN2
0001B
1005 updated PCIe codes for improved compatibility with some GPUs
1004 update microcode and PCIE Gen 3.0 codes
0901 Improve high frequency DRAM compatibility, add more options to Latency Boundary item, enable UEFI driver support for add on cards
0083B More DRAM Tuning, added option under 'Latency Boundary' 'Furthest' - Furthest will help RAM OC higher (especially Elpida Hypers/ BBSE) at the cost of latency, added Load Tight 4x4GB Hynix Profile.
0803 memory timing changes to the gaming OC profile
079B overclocking - more aggressive than 0803
OC Key Firmware:
1003
OC Guides:
ASUS Rampage IV Extreme - UEFI Guide for Overclocking
Rampage-IV-Extreme Manual:
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...IV_Extreme.zip
Post your reviews and I will add to the list. :up:
