EK-FC580 DCII for ASUS GeForce 570/580 GTX DirectCU II monster
The most bad-ass LN2 performer - the ASUS GeForce 580 GTX DirectCU II - gets it's own full-cover waterblock for the times when the card is not running tripple digits cold :p: Waterblock sports brass standoffs and is compatible with both 580- as well as 570 GTX graphics card (mounts with one less screw). It is a fairly high flow (low restriction) waterblock therefore it can be used with water cooling setups using weaker water pumps!
http://file.si/pfiles/189952/DSC_1142.JPG
http://file.si/pfiles/189953/DSC_1143.JPG
Hydraulic curve:
http://file.si/pfiles/189956/ek-fc58..._hydraulic.png
Heatload test (OCP disabled):
http://file.si/pthumbs/large/189954/..._th2o_38-9.jpg
System:
- AMD Athlon II X2 250@4093MHz, 1.525V/1.35Vnb - EK-Supreme HF waterblock
- ASUS Crosshair V Formula - EK-FB ASUS Crosshair V waterblock
- 2x2GB Elpida PSC memory (Exceleram E30104A)
- 650W Corsair TX PSU
- ASUS GeForce 580GTX DirectCU II - EK-FC580 DCII evaluation sample waterblock
- Laing D5 Vario + EK X-TOP V2
- EK-RAD CoolStream XT 360 + 3x120mm Yate Loon D12SL (1650rpm)
- 12mm ID tubing + EK High Flow 12mm fittings
Measuring equipment:
- Greisinger GTH 175/Pt, calibrated
- Voltcraft IR-800 20D
- Digmessa digital flow meter
Tgpu-max = 54°C
TH2O-max = 38.9°C
deltaT = 15.1°C
With this test setup the delta is around 15°C. The hottest part of the card measured with IR thermometer is ~ 55-56°C (PCB behind the MOSFETs).
Compatibility list:
- http://www.coolingconfigurator.com/s...t?gpu_gpus=383
- http://www.coolingconfigurator.com/s...t?gpu_gpus=378
Now... can't wait to put this baby under some 2-stage cascade tripple digit zero cold :cool:
Best Regards,
Niko :up:
