Have just got my MaximusIV-Extreme and i wanted to know whats the latest bios! Currently on bios 0406!
I'm using the latest ''official'' one: 0901.
Everything is working fine, except Windows update messing my Win 7 install by installing ''ACS-6xxx'' drivers, confusing the NEC USB3 and Marvell SATA6 drivers with those. It was a mess. 2 hours of black screen of death, until reading somewhere how to get rid of it. :(
Now everything is fine. Just be careful when installing Windows Update. Be sure to NOT install, and also ''hide'', any ACS-6xxx updates or drivers. There is NO ACS-6xxx component on our board. Windows update is confused.
Thanks mate on 0901 now! Have found newer one to 0951!
Loving this board alot better than my old MSI P67A- GD65 5Ghz Cas6 2232Mhz 6-10-6-27 1T 1.7v
http://img204.imageshack.us/img204/4...hz6106271t.png
you could post a basic configuration for 4800/5ghz bios?
After hours of stability testing (and gaming), I now have my 24/7 settings with my i7 2600K and Asus Maximus IV. Temps never goes over 60 on high-load (Prime, LinX).
4900 Mhz (49X100) @ 1.35v. Great little chip.
http://valid.canardpc.com/show_oc.php?id=1635578
-Vcore = 1.35v
-Intel PLL overvolting = Auto
-VRM Frequency = 350
-Phase Control = Extreme
-Duty Control = Extreme
-LLC = 75%
-Manual RAM timings
Everything else is at auto.
I could probably push it alot more, but for now I'm happy. I was able to do 51X100 at 1.39, but didn't try to go higher:) Have things to do. Will try harder next week-end. Great little motherboard.
A amazing board for Clocking memory!
http://img834.imageshack.us/img834/9...z6106261ti.png
Uploaded with ImageShack.us
Amazing chip/dimms you mean :D
Lucky bastards ... I gotta wait until march/april to get my board ... in the mean time all my new parts are sitting around doing nothing :( At least I got something to look forward to though :)
What ivy bridge!LOL
is any place still selling these?
You can find out how the bios was set to 5ghz?
5.1 (51X100) rock-stable at 1.42v. Was able to play Borderlands 4 hours in a row without any problems at 5.1! :)
-HT ON! Temps are good!
-Intel PLL overvoltage OFF
-LLC Max (100%)
-VRM freq = 350
-RAM settings manual
Everything else on Auto.
I have to work, but tonight I will try pushing it to 5.4. :)
http://valid.canardpc.com/show_oc.php?id=1638690
http://farm6.static.flickr.com/5058/...98fd6189_b.jpg
Pll overvoltage off at 51x?That is a very good chip,stop primming and go test it srsly with some benches ;)
Just before going to work, I was able to try 5.2 (52X100) at the same 1.42v, but got an error in Prime after 50 minutes. :( Not a BSOD, just 1 error on 1 thread.
But now I must work. :(
Now surfing and typing this message at 5.4 (54X100) @ 1.48 with Intel PLL overvoltage OFF! :)
http://valid.canardpc.com/show_oc.php?id=1640461
http://img13.imageshack.us/img13/9417/54x100148.jpg
I'm not a die-hard OCer, so I'm not confortable going over 1.5v... :(
@levesque, might not be a die hard ocer but man that chip is real nice! 5.4 @1.4 :D
I was able to boot at 5.5 (55X100) @ 1.48, PLL overvoltage OFF, but got some errors after 3 minutes in Prime. But I'm ''afraid'' to go over 1.5v. I'm a sissy. :(
Wondering if this has the vcore problem limit like some Asus mobos do? Need to know if it can do over 1.54v.
Only have to disable voltage monitoring in uefi to get rid of the bios error message.
In MivE bios boot option disable hit 'F1' button.."
