Crunching on SSDs: What you need to know
Page 1 of 2 12 LastLast
Good point - I generally move the Swap file off an SSD simply for space reasons anyway, or disable it completely if I have enough ram. Will add that to the 1st post when I get a chance
  • Sorry, jcool, but I don't understand partition "alignment". With a mag. drive, one normally aligns to cylinder boundaries, tho this probably has no advantages as far as the hardware is concerned. Is your magic number the SSD equivalent? Are there any other sizes? What would the DOS or *nix fdisk program say about an "aligned" partition?
  • The Intel RAID driver software has a function even if you do not run RAID - it enables and is necessary for running SATA drives in AHCI mode (XP). You can install it with XP post OS-installation, but you need to patch the registry with a chipset-dependent magic number. I found info at http://forum.msi.com.tw/index.php?topic=106575.0 but that's not online right now. (I might have saved a copy somewhere. Also, the location of the Intel software has changed).
  • It's been awhile since I've read into that alignment stuff, and frankly, I don't really remember the how's and why's simply because it has become unneccessary to do ever since Windows Vista. I do know it makes a difference though. Reason is that SSDs somehow use different block sizes than HDDs, so the file system needs to be adjusted (the written block size needs to match the block size that the SSDs controller uses internally or something). I recommend reading that link to OCZ forums I posted, it explains it a bit better IIRC.
    PS: @jcool - I can't read the yellow text in your 1st post, against the yellow background used by the XS forum, unless I select the text so it shows white against blue. Bad choice of colour, mate.
    No problems here - my background is XS standard grey though. Not sure why yours is yellow?
