1 Attachment(s)
Project Phoenix (Watercooled Li Lian V600)
Hello
I have been watercooling for about a year and a half...My first watercooling rig was a fully watercooled system in a Lian li G60 case...now that i am moving around alot i have desided to build a smaller system so that is more portable...
The new system will be a fully internal watercooled system parts are as follows.... :D
ASUS Rampage III Gene
Core I7 920 D0 (Overclocked 4 Ghz)
Corsair GT 1866mhz (Overclocked 2000 Mhz)
EVGA GTX 460 superclock (Later on SLI)
Intel 80gb SSD (OS)
Western digital Green 1000gb (Storage)
Silverstone 850w PSU
Watercooling parts.... :D
Full cover waterblock for GPU (EK Waterblock)
Cpu watercooled (Swiftech GT)
360 Rad (Noctua U12 Fans)
18w DDC
EK-Multioption RES X2 150mm
Red Tubing with clear coolent
Black Fittings
might later on cool the motherboard... :D
The case will have internal persex panels which will be white and also frosted with white light cold cathodes behind....more about that later....should be starting on the build tomorrow going to take the case apart and start with the cutting of the rad hole and also fan holes......
7 Attachment(s)
The Cutting has started....!!
Well i have been doing some cutting, Door has been cut using a CNC Machine and then Rad Hole the old trust Dremel, I have also mounted the pump....
Let me know what you think....!!!!
9 Attachment(s)
Snow Photos...!!!!!!!!!!!!!
Well because of the weather i had the day off work so i took some photos in the snow...!!!!!
TELL ME WHAT YOU THINK.....!!!!!!! :D
