Project Blueboy - Lian Li V2000
This is my first go at water cooling so go easy on me :)
This started with me wanting a new case as i was getting fed up with the limitations of my old case but rapidly grew into a much bigger project. After looking at many builds I picked up a second hand Lian Li V2000 that had already been powdercoated. It's a huge case full of potential, perfect for what i wanted to do. I quickly rehoused my components and was very happy with the case.
Current spec
Intel i7 920 d0
Asus P6T Deluxe v2
6gb G skill Pi Silver
2x Asus 5770
256gb Kingston ssd snvp325
1.5tb Samsung eco green
Samsung SH-B083L/RSBP
Corsair hx620
Titan Fenrir
Dell 2407 ao4
http://img820.imageshack.us/img820/9301/wc3p.jpg
I wanted to have a virtually silent system while still maintaining a good overclock. Having read about as much as i think my brain could take about watercooling I eventually came up with these parts and took the plunge. I saved some money and picked the cpu block, pump and res up from another forum :)
Heatkiller 3.0 cu
d5 vario
hwlabs sr-1 420
ek multi 250
4xTFC ˝id ľod 45 rotary
8xTFC ˝id ľod compression fittings
3m ˝ id ľ od Primochill LRT blue
3xYate Loon D14SL-124UB
4xYate Loon D12SL-124UB
Scythe Kaze Master
Silver kill coil
Distilled water
and soon a big box arrived :D
http://img3.imageshack.us/img3/9889/wc1vz.jpg
I didn't have alot of time on my first night so i worked on converting the front drive bays to take my hard drives so the lower compartment would be free for the rad, pump and psu.
Lian LI ssd mount
http://a.imageshack.us/img844/279/wc6.jpg
kaze master fitted and hooked up to some exhaust fans
http://a.imageshack.us/img101/5715/wc7x.jpg
The primochill hose has a fantastic colour
http://a.imageshack.us/img688/6994/hose.jpg
hose, fans and cables under uv. I love blue if you hadn't noticed
http://a.imageshack.us/img843/8269/wc4.jpg
I started to familiarise myself with the components, was really nice to actually learn about something new after years of pc components. The sr1 is extremely well made and has a deeper shroud on the side opposite to the inlets.
http://a.imageshack.us/img833/583/rad1.jpg
mocked up with some fans and fittings (fans would be on the other side)
http://a.imageshack.us/img820/1896/rad3.jpg
140mm and 120mm fan comparrison
http://a.imageshack.us/img651/2070/rad2.jpg
Propperly mocked up the rad
http://a.imageshack.us/img832/5695/rad5.jpg
Rad looked like it was sitting too low for my cutout
http://a.imageshack.us/img832/5797/rad7.jpg
I put a couple of 25mm thick fans under the rad and that lined it up perfectly, will need some extruded steel/aluminium for this.
http://a.imageshack.us/img832/2644/rad8.jpg
On Sunday evening i had my first free evening and set out to get the plumbing done. The cpu block and fittings were reasuringly heavy.
http://a.imageshack.us/img832/9343/fittings.jpg
Mobo stripped down and block fitted.
http://a.imageshack.us/img828/227/mobo1.jpg
Fitted the res, leaving enough room for cards much longer than my 5770's
http://a.imageshack.us/img818/5927/res1.jpg
Bolted the rad mount down in its tempary position.
http://a.imageshack.us/img828/4231/mount1s.jpg
The rad took 8 rinses before the water was clear, this was the first.
http://a.imageshack.us/img832/9984/flush1.jpg
So got it all in, was not as tricky as i thought. Slow and steady is the way and take plenty of breaks.
http://a.imageshack.us/img251/1112/testing1o.jpg
d5 vario
http://a.imageshack.us/img413/6028/pumpi.jpg
Leak testing
http://a.imageshack.us/img832/1571/testing2.jpg
Had to see it ll lit up :D
http://a.imageshack.us/img413/2758/testing6.jpg
http://a.imageshack.us/img230/9381/testing4.jpg
http://a.imageshack.us/img801/5302/testing3.jpg
Not completely finished but close. I still need to raise the rad, make a new psu plate and mesh the rad area but its done leak testing and i think i have done alright with my first loop :)
Also going to mod the led fans and add a switch to turn the led's off when i don't want them on. With the fans turned down on the controller the leds dim as well which i hadn't realised would happen but i quite like.
I've got a 5870 coming to replace my 5770's, think its pointless watercooling such cool and quiet cards but i'd like to free up the top slots. Will more than like get the ek-fc5870 acetal and nickel for it and add it to the loop.
http://a.imageshack.us/img835/477/inside2u.jpg
http://a.imageshack.us/img440/5602/exterior1.jpg
Hope you liked my first watercooled build, i know it won't be my last :)
