Corsair H70 picture - Released tomorrow? (updated)
http://gadgetsteria.com/2010/07/30/c...ng-august-1st/
Two pictures in the gallery at the end of the article. The most interesting thing is the SKU Livedate August 1st 2010.
Could any Corsair guys make or kill this rumour?
Edit: http://webcache.googleusercontent.co...ient=firefox-a
Google cache of a removed preorder page, it's either true or got delayed at the last second. From the preorder and article it looks like it will cost about 50% more than the H50, but come with two fans a new cold plate and a thicker radiator. As the preorder page was pulled, we can't really guess at the date, but I could imagine it taking the estimated 10 days from Corsair base to OCUK. At least we know the picture is accurate, as both the OCUK page and the article use the same picture.
Might as well include the stats:
- A new improved cold-plate design more efficiently transfers heat.
- A thicker radiator increases the cooling surface area for even better cooling potential.
- Dual 120mm fans with multiple speed options that let you optimize the maximum cooling and minimum noise.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 50mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Selectable 1600 or 2000 RPM
- Air Flow: 50.35 – 61.2 CFM (per fan)
- Static Pressure: 1.8 – 2.3mm H20 (per fan)
- Noise Level: 26 – 31.5 dBA (per fan)
