ASUS Crosshair IV Formula And 1035T - 24/7 Stable Testing
X6 1035T @ 300x13.5, 4GB Memory @ 1600MHz, Post 1 Of 2
Initial setup. Just like the 4A89TD Pro this board allows locking in the Turbo multipliers in the BIOS. Because of this good CPU overclocks can be obtained without the need for extremely high bus frequency. The downside is the CPU being a non-BE it has a max NB multiplier of 10x so the higher the bus frequency the better the memory performance.
ASUS Crosshair IV Formula, 0707 BIOS
Phenom II X6 1035T
2x2GB OCZ Reaper (OCZ3RPR1800LV6GK) PC3-14400 1333MHz 8-8-8-26
300x13.5, Memory @ 1600MHz 7-7-7-21
OCZ 100GB Vertex LE100
SAPPHIRE 4870x2, 4870 Trifire
OCZ Z Series 850W
click for larger image
http://www.edgeofstability.com/image...os/main1_s.jpg http://www.edgeofstability.com/image...os/main2_s.jpg
http://www.edgeofstability.com/image...os/dram1_s.jpg http://www.edgeofstability.com/image...os/dram2_s.jpg
http://www.edgeofstability.com/image...advanced_s.jpg http://www.edgeofstability.com/image...os/north_s.jpg
Code:
Configure System Performance Settings
Target CPU Frequency:. 4050MHz
Target DRAM Frequency: 1600MHz
CPU Level Up......................[Auto]
OC Tuner Utility
AI Overclock Tuner ..................[Manual]
CPU Ratio............................[13.5]
CPB Control..........................[Disabled]
CPU Bus Frequency....................[300]
PCIE Frequency.......................[100]
DRAM Frequency.......................[1600MHz]
CPU/NB Frequency.....................[3000]
HT Link Speed........................[3000]
> DRAM Timing Configuration
> DRAM Driving Configuration
************* Please key in numbers directly! *************
Extreme OV...........................[Disabled]
CPU & NB Voltage Mode................[Manual]
CPU Voltage........................1.429 [1.400000]
CPU/NB Voltage.....................1.442 [1.412500]
CPU VDDA Voltage.....................2.560 [Auto]
DRAM Voltage.........................1.700 [1.65000]
HT Voltage...........................1.310 [1.27500]
NB Voltage...........................1.310 [1.27500]
NB 1.8V Voltage......................1.802 [Auto]
SB Voltage...........................1.111 [Auto]
VDDR Voltage.........................1.205 [Auto]
VDDPCIE..............................1.113 [Auto]
DRAM CTRL REF Voltage................0.500 [Auto]
DRAM DATA REF Voltage................0.500 [Auto]
CPU Load-Line Calibration............[Auto]
CPU/NB Load-Line Calibration.........[Auto]
CPU Spread Spectrum..................[Disabled]
PCIE Spread Spectrum.................[Disabled]
DRAM CAS# Latency....................7 [7 CLK]
DRAM RAS# to CAS# Delay..............7 [7 CLK]
DRAM RAS# PRE Time...................7 [7 CLK]
DRAM RAS# ACT Time..................21 [21 CLK]
DRAM READ to PRE Time................4 [Auto]
DRAM Row Cycle Time.................28 [28 CLK]
DRAM WRITE Recovery Time.............8 [Auto]
DRAM RAS# to RAS# Delay..............4 [Auto]
DRAM READ To WRITE Delay.............7 [Auto]
DRAM WRITE To READ Delay(DD).........2 [Auto]
DRAM WRITE To READ Delay(SD).........4 [Auto]
DRAM WRITE To WRITE Timing...........4 [Auto]
DRAM READ To READ Timing.............4 [Auto]
DRAM REF Cycle Time................110 [Auto]
DRAM Refresh Rate..................7.8 [Auto]
DRAM Command Rate...................1T [Auto]
DCTO Information:
CKE drive strength................1.5X [Auto]
CS/ODT drive strength.............1.5X [Auto]
ADDR/CMD drive strength...........1.5X [Auto]
MEMCLK drive strength.............1.5X [Auto]
Data drive strength.................1X [Auto]
DQS drive strength..................1X [Auto]
Processor ODT...................60ohms [Auto]
DCTO Information:
CPU Configuration
AGESA Version 3.7.0.1
AMD Phenom(tm) II X6 1035T Processor
Revision: E0
Cache L1: 768KB
Cache L2: 3072KB
Cache L3: 6MB
Speed : 4063MHz
uCode Patch Level: 0x10000BF
Microcode Updation..................[Enabled]
Secure Virtual Machine Mode.........[Enabled]
Cool'n'Quite........................[Disabled]
C1E Support.........................[Disabled]
ASUS Core Unlocker..................[Disabled]
CPU Core Activation.................[Manual]
2nd Core..........................[On]
3nd Core..........................[On]
4nd Core..........................[On]
5nd Core..........................[On]
6nd Core..........................[On]
DRAM Controller Configuration
Channel Interleaving................[Auto]
MemClk Tristate C3/ATLVID...........[Disabled]
Memory Hole Remapping...............[Enabled]
DCT Unganged Mode...................[Always]
Power Down Enable...................[Disabled]
http://www.edgeofstability.com/image.../300_lin_s.jpg
http://www.edgeofstability.com/image.../300_mem_s.jpg
http://www.edgeofstability.com/image...7/300_true.jpg
Code:
x264 HD BENCHMARK 3.0 RESULTS
Please do not compare it with older versions of the benchmark!
Please copy/paste everything below the line to to report your data
Results for x264.exe r1342
encoded 1442 frames, 92.52 fps, 3898.70 kb/s
encoded 1442 frames, 92.35 fps, 3898.70 kb/s
encoded 1442 frames, 92.34 fps, 3898.70 kb/s
encoded 1442 frames, 92.44 fps, 3898.70 kb/s
encoded 1442 frames, 38.37 fps, 3971.80 kb/s
encoded 1442 frames, 38.51 fps, 3972.09 kb/s
encoded 1442 frames, 38.58 fps, 3951.22 kb/s
encoded 1442 frames, 38.69 fps, 3968.90 kb/s
System Details
Name AMD K10
product System Product Name
Codename
Specification AMD Phenom(tm) II X6 1035T Processor
Core Stepping
Stock frequency 3100 MHz
Core Speed 4063.5 MHz
FID range 5.0x - 15.5x
Northbridge ATI ID5A11 rev. 02
Southbridge ATI SB750 rev. 40
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 21
Command Rate (CR) 1T
Memory Frequency 802.7 MHz (3:8)
Memory Type DDR3
Memory Size 4094 MBytes
Channels Dual, (Unganged)
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
Number of processors 1
Number of threads 6
Number of threads 6 (max 6)
L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
Package Socket AM2+ (940)
Package Type 0x1
Temperature 0 34°C (93°F) [0x22] (TMPIN0)
Temperature 1 30°C (85°F) [0x1E] (TMPIN1)
Temperature 0 16°C (60°F) [0x7E] (Core #0)
Temperature 1 15°C (59°F) [0x7B] (Core #1)
Temperature 2 16°C (59°F) [0x7C] (Core #2)
Temperature 3 16°C (60°F) [0x7F] (Core #3)
Temperature 4 16°C (61°F) [0x82] (Core #4)
Temperature 5 16°C (61°F) [0x83] (Core #5)
Switched to a 1090T and some stock memory speed testing
X6 1090T @ 200x20.0, 4GB Memory @ 1600MHz, Post 1 Of 2
ASUS Crosshair IV Formula, 0041 BIOS
Phenom II X6 1090T
2x2GB Platinum AMD Edition OCZ3P1600LVAM4GK PC3-12800 1600MHz 7-7-7-24
200x20.0, Memory @ 1600MHz 7-7-7-24
OCZ Z Series 850W
Code:
Target CPU Frequency:. 4000MHz
OC Tuner Utility
CPU Ratio............................[20.0]
CPU Bus Frequency....................[200]
HT Link Speed........................[2600]
CPU Voltage........................1.482 [1.450000]
CPU/NB Voltage.....................1.396 [1.350000]
CPU VDDA Voltage.....................2.560 [2.50000]
DRAM Voltage.........................1.687 [1.63750]
HT Voltage...........................1.336 [1.30000]
NB Voltage...........................1.296 [1.26250]
NB 1.8V Voltage......................1.802 [1.802000]
SB Voltage...........................1.111 [1.113000]
VDDR Voltage.........................1.205 [1.205750]
VDDPCIE..............................1.113 [1.113000]
CPU/NB Load-Line Calibration.........[Enabled]
DRAM RAS# ACT Time..................24 [24 CLK]
DRAM READ to PRE Time................6 [Auto]
DRAM Row Cycle Time.................31 [31 CLK]
DRAM WRITE Recovery Time.............12[Auto]
DRAM RAS# to RAS# Delay..............6 [Auto]
DRAM READ To WRITE Delay.............6 [Auto]
DRAM WRITE To READ Delay(SD).........6 [Auto]
DRAM Command Rate...................1T [1T]
DCTO Information:
Data drive strength................1.X [Auto]
DQS drive strength.................1.X [Auto]
DCTO Information:
CPU Configuration
AMD Phenom(tm) II X6 1090T Processor
Revision: E0
Cache L1: 768KB
Cache L2: 3072KB
Cache L3: 6MB
Speed : 4013MHz
CPU Core Activation.................[Auto]
http://www.edgeofstability.com/image...3000_lin_s.jpg
http://www.edgeofstability.com/image...3000_mem_s.jpg
http://www.edgeofstability.com/image..._3000_true.jpg
Code:
encoded 1442 frames, 90.62 fps, 3898.70 kb/s
encoded 1442 frames, 90.80 fps, 3898.70 kb/s
encoded 1442 frames, 90.71 fps, 3898.70 kb/s
encoded 1442 frames, 37.93 fps, 3969.80 kb/s
encoded 1442 frames, 38.15 fps, 3970.05 kb/s
encoded 1442 frames, 38.24 fps, 3969.43 kb/s
encoded 1442 frames, 38.12 fps, 3968.99 kb/s
System Details
Name AMD K10
Codename
Specification AMD Phenom(tm) II X6 1090T Processor
Core Stepping
Core Speed 4013.5 MHz
Cycle Time (tRAS) 24
Memory Frequency 802.7 MHz (1:4)
Memory Type DDR3
Number of threads 6
Package Type 0x1
Temperature 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature 1 37°C (98°F) [0x25] (TMPIN1)
Temperature 0 35°C (94°F) [0x115] (Core #0)
Temperature 1 35°C (94°F) [0x117] (Core #1)
Temperature 2 35°C (94°F) [0x118] (Core #2)
Temperature 3 35°C (94°F) [0x118] (Core #3)
Temperature 4 35°C (94°F) [0x116] (Core #4)
Temperature 5 35°C (94°F) [0x116] (Core #5)
1090T @ 4200, memory - 1640 CAS6
X6 1090T @ 205x20.5, 4GB Memory @ 1640MHz, Post 1 Of 2
ASUS Crosshair IV Formula, 0905 BIOS
Phenom II X6 1090T
2x2GB Super Talent Speed Series (WS220UX4G8) PC3-17600 2200MHz 8-8-8-24
205x20.5, Memory @ 1640MHz 6-6-6-18
OCZ Z Series 850W
Code:
Target CPU Frequency:. 4202MHz
Target DRAM Frequency: 1640MHz
OC Tuner Utility
CPU Ratio............................[20.5]
CPU Bus Frequency....................[205]
DRAM Frequency.......................[1640MHz]
CPU/NB Frequency.....................[2870]
HT Link Speed........................[2665]
CPU Voltage........................1.554 [1.521875]
CPU/NB Voltage.....................1.415 [1.381250]
NB Voltage...........................1.257 [1.22500]
DRAM CTRL REF Voltage................0.500 [0.500]
DRAM DATA REF Voltage................0.500 [0.500]
CPU Load-Line Calibration............[Enabled]
DRAM CAS# Latency....................6 [6 CLK]
DRAM RAS# to CAS# Delay..............6 [6 CLK]
DRAM RAS# PRE Time...................6 [6 CLK]
DRAM RAS# ACT Time..................18 [18 CLK]
DRAM Row Cycle Time.................24 [24 CLK]
DRAM WRITE Recovery Time............12 [Auto]
DRAM RAS# to RAS# Delay..............5 [Auto]
DRAM REF Cycle Time.................90 [90ns]
DCTO Information:
DCTO Information:
CPU Configuration
Revision: E0
Cache L1: 768KB
Cache L2: 3072KB
Cache L3: 6MB
Speed : 4013MHz
http://www.edgeofstability.com/image...4200_lin_s.jpg
http://www.edgeofstability.com/image...4200_mem_s.jpg
http://www.edgeofstability.com/image.../4200_true.jpg
Code:
encoded 1442 frames, 95.40 fps, 3898.70 kb/s
encoded 1442 frames, 95.49 fps, 3898.70 kb/s
encoded 1442 frames, 39.95 fps, 3965.26 kb/s
encoded 1442 frames, 40.07 fps, 3968.62 kb/s
encoded 1442 frames, 39.88 fps, 3971.98 kb/s
encoded 1442 frames, 40.14 fps, 3954.70 kb/s
System Details
Name AMD K10
Codename
Core Stepping
Core Speed 4250.1 MHz
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Memory Frequency 829.3 MHz (1:4)
Memory Type DDR3
Number of threads 6
Package Type 0x1
Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
Temperature 1 35°C (94°F) [0x23] (TMPIN1)
Temperature 0 38°C (101°F) [0x133] (Core #0)
Temperature 1 38°C (100°F) [0x131] (Core #1)
Temperature 2 38°C (100°F) [0x12F] (Core #2)
Temperature 3 38°C (99°F) [0x12D] (Core #3)
Temperature 4 38°C (99°F) [0x12D] (Core #4)
Temperature 5 38°C (99°F) [0x12C] (Core #5)
