PCI-E Gen 2.0 Bug X38/ X48/X58
Hi guys
In collaboration with a number of users on the nVidia forums and ASUS forums I am trying to collect data as to what boards are effected by the notorious PCI-E Gen 2.0 bug which appears to be effecting Dual PCI-E 16 Intel Boards and nVidia cards.
The symptoms of the PCI-E Gen 2.0 bug are that your graphics card only operates at PCI-E Gen 1.1 mode.
For example
http://img13.imageshack.us/img13/4130/pcie201stslot.jpg
This GTX 285 is only operating @ PCI-E 1.1 x16 on an X38 based motherboard (ASUS P5E3).
On gigabyte boards the symptoms are slightly different.
http://img215.imageshack.us/img215/4...en11bug.th.jpg
Where here the board does present itself as a Gen 2.0 board, the card only runs at Gen 1.1
I and a few other users have been constantly trying to get this issue resolved, but motherboard vendors are not very helpful.
The information we have is
1) PCI-E Gen 2.0 has been disabled on X38/x48/X58 boards with a certain undisclosed, yet confirmed by nVidia SMBIOS bug in Intel BIOSes as of April 2009.
2) Intel DX38BT motherboard with BIOS 2006 is NOT effected by the PCI-E Gen 2.0 bug, apparently this contains a fix.
3) DMI information on ASUS X38 boards is odd, says our PCI-E16 slots are empty?!
4) Intel resolved a Slot mismatch issue on their boards in July 2009 stating it resolved a PCI-E Gen 2.0 issue.
5) Most X48 boards are unaffected, and even fewer X58 boards have this bug.
6) nVidia 9800GX2 and GTX295 do not appear to show this bug as their NF200 chips report the PCI-E link speed direct to the GPU's
Please if you have the time could you take a screenshot of GPU-Z showing your card's PCI-E transfer rate and put this alongside a CPU-Z screenshot showing what motherboard and what BIOS revision you are running.
Many thanks
John
