SteveRo,
3-4 X25-V's are really fast, GullLars and I spent most of the weekend benching, creating graphs and comparing the results to other setups.
We compared G1's and G2's in different setups and the V did really well.
I'll try to get GullLars to post a few graphs showing the results.
Would you mind running your Areca/X25-V using the same iometer config file we used last weekend?
If you've still got the Acards I'd appreciate if you could try the same script on a few of those :)
Attachment 101167 IOmeter 0.5-64KB QD1-128 config file
Use 4x cache size as the testfile length, except for ICH which is 1GB default.
The test is read only.
Tiltevros,
You can download the Technical Preview using this
Link
